Make Your Own Knife
Intro: Make Your Own Knife
Hello again! This is an instructable on how to make a simple knife. In fact, you will just be making the wooden handle, as making the blade itself requires a lot more tools and knowledge than I have.
Oh, and a disclaimer: Knives are sharp and some tools potentially dangerous. Use protection. Really, I mean it.
There-let's start!
STEP 1: Materials Needed
For this specific knife you will need the following:
- a blade
- a piece of nice wood for the handle
- a thin piece of brass/metal for the guard
- a few pieces of coloured distance material
STEP 2: Drilling a Hole for the Blade Shaft
This is a step that requires some patience and control. Get it wrong and you may have a shaft protruding from the side of the handle - or a crooked knife. Draw a line on the outside of the wood and try to keep the drill aligned. You may have to drill two or three holes next to each other to get a sufficiently big hole for the shaft. This can be tricky without a mounted drill rig, but possible.
STEP 3: Prepare the Metal Guard
Drill two or three holes in order to get a hole big enough to fit the knife. Shape a rektangular hole using a very small file. Sandpaper and polish the side that will be exposed. It will be harder to do afterwards as the blade will be in the way.
STEP 4: Test the Spaces and Metal Guard
Make sure that all pieces fit together as planned.
STEP 5: Glue It All Together
Here I would suggest that you use a two component glue. Make sure you get enough glue into the hole in the wood piece. And between all the pieces. Don't worry about excess glue. It will be sanded off later.
STEP 6: Let It Dry
Use your imagination in order to put the knife under pressure during the drying process.
STEP 7: Take a Break
Take a well deserved break!
STEP 8: Prepare for Sanding
When dry, it is time to start sanding.
STEP 9: Set Up Sanding Tools
There are many different tools that can be used for sanding. The picture shows my choice and setup.
STEP 10: Get a Rough Shape
This is where your creativity comes to play. Make up your mind on how you want the knife to look like when finished. Start sanding, but take it slow as rotation sandpaper eats the wood fast.
STEP 11: Refine the Shape
Refine the shape using files and some 40 grade sandpaper.
STEP 12: Work Out the Details
When you are satisfied with the shape start using 80 grade paper and gradually change to 200, 400, 800 and1200 paper.
STEP 13: Get That Smooth Finish
Keep sanding!
STEP 14: Add Oil
When satisfied with the finish, add some oil. In my case I used olive oil.
STEP 15: Take a Step Back and Feel Satisfied
... and finished!
24 Comments
satcchi.08 9 years ago
ffrisell 9 years ago
I am happy that you enjoyed the Instbl. As "for what good" it is to make a knife handle without making a knife blade:
1. There is not really any "for what good". I just enjoy making knife handles and to buy the blades ready-made.
2. Making of a knife blade requires expensive equipment, such as a furn for tempering/hardening of the blade.
3. Metal treatment also requires knowledge which I don't have (yet). If you get the heat treatment wrong, you may end up with a very brittle blade. That could be somewhat dangerous when the knife is put to use.
Having said that, I am hoping to one day to be able to make my own knife blades as well. Especially damascus style blades seem interesting to work with.
/Frederik
Holje 9 years ago
Great handle! P
What are the distance materials from? What can I use for the purpose?
brather 9 years ago
olive oil is agood idea.. but how long it takes to dry? and after that, is it sliding softly or glueing in the hand?
PowellMade 9 years ago
I like your glue jig. Did you have to put the screws in on an angle?
Hi PowellMade,
No angle on the screws. Just fasten one screw, then turn the woodpiece to desired pressure on the knife and screw in the other. But the pressure was relatively low. Don't want to press all the glue out.../Frederik
bartworker 9 years ago
Simple & beautiful, that looks like a great bushcraft knife!
I disagree at one point: a beer is so much better to wipe the dust away ;)
alcurb 9 years ago
I'm curious about your drill adapter to rotary sander. Did you make it yourself or did you buy it somewhere? I would like one but I need the details. Thanks.
Thanks for the nice comment! Please se photo of the adapter. Maybe you can find it at a hardware store.All the best/Frederik
Professor-Mousedude 9 years ago
What kind of wood did you use for the handle?
Flash67 9 years ago
Google "scandanavian knife blanks". They tend to be very high quality steel and are often quite inexpensive. Best place I've seen to buy them in the USA is a place called "ragweed forge".
Tecwyn Twmffat 9 years ago
I saw a blacksmith make a blade out of an old file yesterday.
Jobar007 9 years ago
I like this knife. It is really practical. One question though: why not do rough shaping of the handle before you have a blade in it? That way you are less likely to damage the blade when doing the roughing out.
GAM3D1FF1CULTY 9 years ago
A short knife is a handy tool for being out and about. Long knives have limited use due to being much more dangerous.
Bowie and Rambo style knives have one purpose: killing people. They are impractical anywhere else.
MandalorianMaker 9 years ago
