Introduction: Making a Controller for a Shower Water Heater.
My shower has a heater head to give me that much needed warm water for my baths. These heaters are cost effective however easily fail if left ON when the water is turned OFF.
This instructable is an after the fact publication. I have designed and built a controller to safely turn off the heater should I exit the shower and forget to manually turn off the power. This system has been working flawlessly for the past 6 years.
I hope you may find this information useful.
Step 1: Having a Working Design.
This is the wiring diagram for my shower head heater. Right after the 120volt AC power is a push button normally open momentary switch. This switch will apply power to the 12vdc and 5vdc power supplies (PSUs).
The PIR motion sensor once powered via 5vdc, it will close its normally open relay contact to allow 120volt AC power to the main Power relay coil.
Once the main relay coil is energized, one of its normally open contacts will bridge the ON push button to maintain power to the entire circuit. The two remaining normally open contacts of this relay are wired in parallel (for longer service life) to send 120volt AC power to the water heater.
Now the heater stays energized once there is motion in the shower.
The entire circuit can be manually turned off by the OFF pushbutton normally closed momentary switch.
If the water pressure is low or not available from the local utility, I use the toggle switch to turn on the water pump. This switch sends 12volt dc power to actuate a relay to provide power to my solar powered pump. This pump will turn off when I manually power down the heater or the PIR sensor detects no further motion.
Step 2: Installing the PIR Sensor.
This sensor I had from an old solar powered floodlight. It works great off 5Volt dc and in order for it to work in this project I turned the lux and sensitivity knobs fully clockwise.
The time delay off knob I adjusted for 10 seconds of inactivity. Therefore after I walk out of the shower, the PIR will turn off the heater circuit and water pump (if the pump switch was ON).
This sensor has only 1 relay with a normally open contact. This contact permits 120volt AC power to the main relay coil.
I used double sided tape to mount it on the wall facing into the shower to detect body heat. Thankfully it ignores the warm flowing water. During a shower it will turn off the heater if I stand still for too long.
Step 3: The Controller Box.
I mounted an 8x8 pvc box on the wall to put all the necessary components and wiring.
The water pump 12volt relay is actually in another location. All the controller box does is send 12volt power to actuate the relay thereby allowing the pump to run.
The led is a color changing type to visually indicate that the heater is energized. This led is powered from the 5Volt power supply.
All the high current wiring for the heater I soldered to the main Power relay. This ensures electrically secure connections and eliminates high resistance joints. Initially I used a socket base for the main Power relay however it failed eventually due to a weak mechanical lug connection.
Step 4: Completion!
Using split loom to tidy up the wiring, the project is complete. This controller extends the service life of the water heater and provides increased safety.
I have peace of mind with this implementation and highly recommend it to anyone with these types of heaters.
12 Comments
6 years ago
Hi! I have been using this type of shower head for over 25 years with no incidents! We use a Venezuelan design - Corona / that relies on water pressure to turn it on and of. This shower head provides two temperature levels (2.5 and 3.0 kw). The switch is actioned by a rubber diaphragm that isolates the switch from direct contact with the water. Both heater elements and the diaphragm switch are available as spare parts. I have gone thru two heads (Actually three, but the third one was destroyed by a lightning bolt that struck about 20 feet from the shower. fortunately nobody was home at the time) We do install them on a dedicated circuit with a dedicated grounding bar! Other than cleaning and inspection about every 6 months, nothing else has to be done. I do keep a full set of spares, AND a spare shower. They are fairly cheap at 14,000 BSf *about 13 Us$!
Reply 6 years ago
So true! I love them at their reliability and availability of spare parts.
6 years ago
FYI The best part of it is that it works at very low water pressure (7psi and up). The instalation instructions prescribe a flow restrictor (included) for water pressures above 20psi
7 years ago
it seems dangerous
7 years ago
I know these showers in Colombia. They turn on and off with the water. The older, used ones are really crappy. Do they wear out? How long will the inexpensive ones last? Any difference in durability for the 110 & 220 volts?
Reply 7 years ago
they fail pretty fast if they are not turned off with the water (plus its a fire hazard). I'm guessing identical durability with both voltages.
7 years ago
All electric showers i know only heats when there is water flowing. I dont see why you need to turn it off after use it
Reply 7 years ago
Low cost units like mine are just a plain heater. There is a mandatory need to turn it off. So, you are telling me you trust a flow sensor in the higher end units to consistently shutoff the unit? You need to think carefully about your use of shower head heaters.
7 years ago
Wow, this brings back memories of living in Brazil 7 years ago. I remember these rarely lasted over a year. If I move back I'll need to do this.
Reply 7 years ago
I typically change the heating element once every 5 years.
7 years ago
Intresting idea!
Have a great day! :-)
Reply 7 years ago
Thanks!
