Making a Guitar Out of a Skateboard #HMS2018
Introduction: Making a Guitar Out of a Skateboard #HMS2018
Today I'm going to showing you guys how to make a guitar out of skateboard.
To do this you will need:
1.skateboard
2.Guitar Nut
3.Guitar Bridge
4.Guitar Tuners
5.Guitar Strings
6.Dry Erase Marker
7.Drill & Drill bits
8.Hammer
9.Screw Driver
10.Screws
11.Pliers
12.Tape Measure
13.Gloves & Goggles (For Safety)
14.Super Glue
15.A specimen over 18 (For Safety)
Step 1: Mark the Place for Your Tuners
Use a dry erase marker to draw the tuner hole on the side you are using to put the tuners.Measure the placement of the holes and then drill the holes to the right size of the tuner.
Step 2: Put Your Tuners in the Holes
After you are done with your holes, put your tuners into the guitar.Put spacers into the pack of the skateboard guitar (they usually come with guitar tuner packs).After you have the spacers in, put the screws in and you will be done with the tuner part (FOR NOW).
Step 3: Install the Bridge
First your going to need to figure out where you want your bridge to be.The best place for me was the middle of the holes from where the trucks used to be.Then, you have to drill the right sized hole inside the hole part of the bridge.Finally, you must screw in the bridge.
Step 4: Putting in the Nut
My nut didn't have any holes to screw into my skateboard, so I used super glue to put it a little bit above where the truck used to be.After that the last thing now is to put the strings on the guitar.
Step 5: Put the Strings on the Guitar
To put strings on the guitar you have to put the string in the bridge.Then you pull the string to the tuner.Finally, you must wrap it around the tuner and cut the string with pliers when your done.
Step 6: Finishing Product
I was putting my chord in and it broke, so now it's a five string guitar.I'm basically Keith Richards.
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • For the Home Contest
    2 Comments
    carvillbond1
    carvillbond1
    24 days ago on Introduction
    On this day I was super proud of my daughter breaking the tools out and making her skateboard guitar. Good job 😘
    bfarm
    bfarm
    5 years ago on Step 6
    More of a zither than a guitar.
