Making a Peanut Butter Brownie Cake
Introduction: Making a Peanut Butter Brownie Cake
How to make a peanut butter brownie cake.
- Browine mix
- Two eggs
- 3 tablespoons of water
- 1/2 cup of vegetable oil
- Whisk
- Bowl
- Peanut butter
- Frosting (optional )
- Sprinkles ( optional )
Step 1: Adding Ingredients
After I took out my bowl, I started adding the brownie mix first into my bowl. Then I put the two eggs, 1/2 cup of vegetable oil and 3 tablespoons of water. After that I took my whisk and started mixing it.
Step 2: Adding Peanut Butter
Next thing I did after adding all the ingredients was adding peanut butter into the mix. I put 2 spoons of peanut butter and mixed that after.
Step 3: Putting It Into the Pan
Once you have mixed all your ingredients into your bowl and your mix looks good, get a stick of butter or you can use pam and apply it all over the pan for the mix to go into. After you’ve done this, add your mix into the pan for it to go into the oven.
Step 4: Putting It in the Oven
I heated my oven to 350 degrees based on the size of my pan. After I put my pan into the oven, I set a timer for 20-23 minutes also based on my pan size.
Step 5: Out of the Oven
Once my timer went off and my browines were done cooking, I took them out of the oven and set them aside to cool down.
Step 6: Adding Frosting
For the outside of my brownie cake I wanted to add frosting by melting white chocolate melts. I did this by putting the chocolate melts in a bowl and put it in the microwave for 30 seconds and stirred them after.
Step 7: Finishing Touches
After my frosting was done I poured it into a plastic bag and cut open the end to put my frosting over the cake. I also added sprinkles and decorative beads/ pearls as well.
Step 8: Final Product
After I added all my finishing touches I cut my brownies and they were done!
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Big and Small Contest
