Introduction: Making an Avocado Hair Mask
Natural way to moisturize dry, damaged hair.
This instruction set requires the use of a knife.
Step 1: Gather Materials
- 1 Avocado (ripe)
- 2 tablespoons of Raw Honey
- 3 tablespoons of Extra Virgin Olive oil
- Bowl
- Knife
- Spoon
- Fork
- Measuring cups
- Cutting board
- Storage container
Step 2: Prep Cutting Station
Place your cutting board in front of you and grab your knife and your avocado.
Step 3: Cut the Avocado in Half
Start at the thinner part of the avocado and cut down to the pit and then work around the avocado until you reach you original starting place. Then separate the halves.
Step 4: Remove the Pit
Easy way to remove it is to take your knife and hit the pit hard enough with the sharp side the it gets stuck, then twist and remove.
Step 5: Cut Within Each Half of the Avocado
Cut within each half horizontally and vertically, be careful not to cut through the skin of the avocado. You will end up with multiple smaller sections that will be easier to mash
Step 6: Scoop the Avocado Into Your Bowl
Using your spoon, scoop each half of the avocado into you bowl.
Step 7: Mash the Avocado
With your fork begin pressing on the avocado and mashing it until the consistency is all even. This may take a bit of time but, the smoother it is the better.
Step 8: Add 2 Tablespoons of Honey
Using your measuring cups carefully measure out 2 Tablespoons of honey and add it to your bowl.
Step 9: Add 3 Tablespoons of Olive Oil
Grab your measuring cups again and measure out 3 Tablespoons of olive oil and add it to your bowl.
Step 10: Stir the Ingredients
Using your spoon stir all the ingredients until they are mixed all together. At this time, you can go back in with your fork and mash any clumps that still remain
Step 11: Place Your Completed Mask in a Container
Carefully dump your mask into the storage container of your choosing. At this time, you can also begin using the mask and then store any extra in your container.
Step 12: Store Your Mask in the Fridge
Keep refrigerated until you are ready to apply your mask.
