Introduction: Massduino-UNO-CORE
The MINI Arduino UNO, Very beautiful, Very useful.
Features
○ MD-328D core module
○ Onboard 3.3V LDO
○ Standard USB2Serial interface for uploading and debugging
○ Onboard 2.4GHz RF Module (Optional)
○ 100% Arduino development environment
○ Vertical double row connector, minimum size on the main board
○ Full UNO IO supported
Step 1: The Devices
To use Massduino-uno-core, you must use UC-2102 and the adapter plate, Massduino-uno-core is not a new product.We have released the Arduino-uno-core before. why we need to release Massduino-uno-core,It's because of the MCU MD-328-D, it is more powerful than 328P, but low cost, so why don't we create a more cost-effective uno - core? So Massduino series was born. the most special is the Massduino-core, so I write this article to introduce Massduino-uno-core.
Step 2: The MD-328D
MCU: MD-328D 32K Flash 2K SRAM 16bit ADC
Working Voltage : 3.3V with onboard LDO
Input Voltage: DC 4.5 to 12V
3.3V Output Current : 300mA MAX
PCBA Size: 20 x 35mm
Bootloader preprogramming : Massduino MD-328D I put Datasheets there, help it can help you.
Step 3: The Massduino-uno-core
We do the demo to show the operation of Arduino-uno-core,
Step 4: Connect
Connect the UC-2102, the adapter plate and Massduino-uno-core
Step 5: The Configuiation
Open the Arduino IDE and check the configuration and download.
Step 6: Results
Then you can see the LEDs start flowing.
Step 7: The Code
boolean state = false;
void setup() {
// put your setup code here, to run once:
for (int i = 0 ; i < 22 ; i++ ) { pinMode( i , OUTPUT );
digitalWrite( i , LOW );
void loop() {
// put your main code here, to run repeatedly:
if (state) {
delay(100);
digitalWrite( 0 , LOW );
delay(800);
digitalWrite( i , HIGH );
delay(100);
state = false;
else { for (int i = 22 ; i >0 ; i-- )
{ digitalWrite( i , LOW ); delay(100); }
state = true;
Step 8: The Video
Step 9: Https://www.ebay.com/itm/222990465577
https://www.ebay.com/itm/222990465577
UNO Core
https://www.ebay.com/itm/221940721765
UM-UNO design LED IO status indicator & Prototype DIY shield for Arduino UNO R3
https://www.ebay.com/itm/321724908832
USB 2.0 SERIAL for Arduino UC-2102 USB to UART Cable 2.45mm to 2.0mm
