Introduction: Meshmixer: Generate Supports
In this section of the user manual we'll walk you through support generation.
Meshmixer for Ember User Manual
Step 1: Generate Supports
To automatically generate supports for your model in Meshmixer.
- Click on the model you want to support.
Tip:
If you want to support multiple models in one go, you should first combine the models.
- Click "Analysis" on the left toolbar and then "Overhangs"
- In the "Overhang" menu, make sure that "Autodesk Ember" is selected in the top drop down menu
- Click "Generate Support", supports will automatically be created for your model
- Individually supports can be deleted by secondary clicking on them
- On Mac: CMD+click
- On Windows: CTRL+click
Note: | DO NOT click "Convert to Solid" |
Tip: | To learn more about support generation read the Advanced Support Generation Tutorial |
5 Comments
Question 1 year ago on Step 1
I import a model, click analysis, click overhangs,set Autodesk Ember in the preset box, then click Generate Supports. Nothing happens! What did I do wrong?
4 years ago
I convert to solid, creating new object (it will keep original model, then make a model of the supports), highlight both objects then combine...this way it doesn't make weird broken pilars...
Question 5 years ago on Step 1
Why not make solid? Where is Advanced Support Generation Tutorial?
Thank you
6 years ago
Presumably this is all aimed at someone using an Ember 3D printer, and someone with a different printer should *NOT* choose "Autodesk Ember" in the first dropdown menu, and should probably adjust the various settings as best they can. In particular, the Y-offset should be set to 0. It seems to me that the right workflow then is to "Convert to Solid" then use (e.g.) Slic3r to produce the Gcode.
Where can I find the "Advanced Support Generation Tutorial" as per the "Tip"?
7 years ago
I've been experimenting with this. Why not convert to solid? I've noticed my prints fail when i do that.
