Introduction: MesoTune - Magnetic MIDI Controller
Note: I want to give credit of this project to by Alex Bluhme. So please check it out here https://vimeo.com/171612791.
Are you a music composer, melodist, symphonist or a tunesmith who loves to create their own beats, but got bored with all those push button traditional MIDI Controllers.
So, this hardware is for you, as in this instructable we switched the push button with a series of discs containing with easily swappable sphere magnets which will synthesis complex beats. This Instructable is to simiplify the sound sampling and enhance your creativity in the field of beat making.
Let's Hope you enjoy and let's begin!
Step 1: How It Works?
MIDI - Musical Instrument Digital Interface, MIDI is an electronic musical instruments, software, computers and other digital controllers share musical information.
Best way to understand what MIDI is to first understand what it is not:
- MIDI isn't music
- MIDI doesn't contain any actual sounds
- MIDI isn't a digital music file format like MP3 or WAV
MIDI is nothing more than data -- a set of instructions. MIDI data contains a list of events or messages that tell an electronic device (musical instrument, computer sound card, cell phone, et cetera) how to generate a certain sound. Here are a few examples of typical MIDI messages:
- Note On signals that a key has been pressed or a note on another instrument (like a MIDI guitar or clarinet) has been played. The Note On message includes instructions for what key was pressed and at what velocity (how hard the note was played).
- Note Off signals that the key has been released or the note is done playing.
- Polyphonic Key Pressure is a measurement of how hard a key is pressed once it "bottoms out." On some keyboards, this adds vibrato or other effects to the note.
- Control Change indicates that a controller -- perhaps a foot pedal or a fader knob -- has been pressed or turned. The control change message includes the number assigned to the controller and the value of the change (0-127).
- Pitch Wheel Change signals that the pitch of the note has been bent with the keyboard's pitch wheel.
[source: How Stuff Works]
Step 2: The Mechanism
Step 3: The Design
Complete Project is designed in Solidworks while keeping all the parameters for additive manufacturing, using off the shelf-components, compact and desktop friendly design, precise and cost efficient.
Step 4: What Components We Need?
Electronic Components:
- 1x Arduino Micro
- 1x Arduino Mega Pro Mini
- 1x TTP229 16 Key Touch Pad
- 1x TM1637 4-bit 7-Segment Display
- 8x A3144 Hall Sensor
- 8x 22K 30mm Slider Potentiometer
- 1x 28-BYJ48 Stepper Motor
- 1x ULN2003 Stepper Motor Driver Board
Hardware Components:
- 2x 688zz Bearing
- 128x 4mmx1.5mm Neodymium Magnets
- 128x 5mm Spherical Neodymium Magnets
- 1x 184mm Length 8mm Dia Shaft
- 2x M3x30 Bolts
- 2x M3x25 Bolts
- Matt Black and Matt White Spray Paints
Tools:
- 3D Printer
- Allen Keys
- Plier
- Screw driver
- Soldering Station
- Glue Gun
Step 5: FDM 3D Printing
We printed bigger parts on FDM 3D Printer
My FDM 3D Printer Settings:
- Material (PLA)
- Layer Height (0.2mm)
- Shell Thickness (1.2mm)
- Fill Density (20%)
- Print Speed (60mm/s)
- Nozzle Temp (210°C)
- Support Type (Everywhere)
- Platform Adhesion Type (None)
You can download all the files that are used in this project -
Base Cover full size.STL
Base Cover Left.STL
Base Cover Right.STL
Base full size.STL
Base Left Side.STL
Base Right Side.STL
Coupler.STL
Magnet Wheel Spacer 8.5mm.STL
Magnet Wheel Spacer 10mmn.STL
Magnet Wheel Spacer x7.STL
Magnet Wheel x8.STL
Motor Cover.STL
Standoffs 20mm x2.STL
Wheel Mount Left.STL
Wheel mount Right.STL
Step 6: DLP 3D Printing
We printed smaller parts which required higher details and smoother surface on DLP 3D Printer
My DLP 3D Printer Settings:
- Layer Thickness (0.05mm)
Step 7: Assembly of Electronics in the Base
To assemble the electronics we will need following parts:
- 1x Base (3D Printed Part)
- 1x Arduino Micro
- 1x TTP229 16 Key TouchPad
As described in the images, snap fit all the components in their respective places. No need of bolts or glue is required as designing is done with all tolerances and all the components gets fit on their own.
Step 8: Assembly of Electronics Components in Motor Cover
- 1x Motor Cover (3D Printed Part)
- 1x LCD Cover (3D Printed Part)
As described in the images, plug in the stepper motor and 4-bit 7-Segment Display at their respective places. And paste the LCD Cover which will hide the LCD and only allow the light to pass through.
Step 9: Assembly of Magnet in Magnet Wheels
- 8x Magnet Wheels (3D Printed Part)
Here, we will insert the disc magnets in each slot of the magnet wheel. This will allow us to swap the spherical magnets with ease.
Follow the step with all 8 Magnet Wheels, and prepare the magnet wheel assembly for next step.
NOTE: Make sure to face the South pole of the Disc magnets towards outside while the North Pole facing towards the center of the Magnet Wheel
Step 10: Assembly of Magnet Wheels on Shaft
- 8x Magnet Wheels Assembly (3D Printed Part)
- 7x Magnet Wheel Spacer (3D Printed Part)
- 1x Magnet Wheel Spacer 8.5mm (3D Printed Part)
- 1x Magnet Wheel Spacer 10mm (3D Printed Part)
- 1x Coupler (3D Printed Part)
- 2x M3 Grub Screws
Here, Insert the 'Magnet Wheel Spacer 10mm' till the extreme left end of the Shaft, after that start inserting all the 8 'Magnet Wheels Assembly' following with the 'Magnet Wheel Spacer' and plug in the 'Magnet Wheel Spacer 10mm'. At extreme right end of the shaft, plug in the Coupler and fix them using M3 Grub Screws.
Step 11: Complete the Assmebly
To assemble the electronics we will need the following parts:
- Assembly of Electronics in the Base
- Assembly of Electronics Components in Motor Cover
- Assembly of Magnet Wheels on Shaft
- 1x Wheel Mount Left (3D Printed Part)
- 1x Wheel mount Right (3D Printed Part)
- 2x Standoffs 20mm (3D Printed Part)
- Slider knob (3D Printed Part)
- Slide Pot Cover (3D Printed Part)
- Base Cover full size (3D Printed Part)
- 2x 688zz Radial Bearing
- 2x M3x30 Bolts
- 2x M3x25 Bolts
- 2x M3x20 Bolts
- 5x M3x10 Bolts
In this step, we will compile all the subassemblies, and complete the assembly. Fix the bearing in the slot given in both the 'Wheel Mounts'. Then mount the 'Motor Cover assembly' on 'Wheel Mount Left' using M3x30 bolts and 3D Printed Standoffs. After that Install the 'Magnet Wheels on Shaft Subassembly' on the 'Wheel Mount'. Follow the images given in this step to complete the assembly.
Paste Slide Pot Covers on the Base around the Potentiometers and Fix the Slider Knob on the Potentiometer's Lever.
Your assembly is complete and ready for the wiring.
Step 12: Arduino Micro Firmware
MIDI Interface Firmware
For communicating with the Laptop/Computer via MIDI interface we'll be using Arduino Micro's ATmega32U4 microcontroller.
We used mocoLUFA MIDI firmware compiled for ATmega32U4.
Using mocoLUFA firmware, Arduino Micro will works as a native MIDI device which sends MIDI command to Laptop/Cmputer via USB port.
Also, mocoLUFA firmware provides the Arduino Serial mode in order to flash firmware on the connected controller.
Instructions to follow:
- Extract the Arduino Micro Firmware compressed file.
- Compile the firmware using 'make all' command
- Wire the Arduino Micro with Arduino Uno (Arduino as ISP)
- Upload dualMOCO.hex and dualMOCO.eep to the Arduino Micro using AVRDUDESS program. (LINK)
Source : Github
Step 13: Wiring
Follow the Schematic to wire all the electronics in the following way:
Arduino Micro <==> Arduino Mega TXD RXD RXD TXD
Arduino Mega <==> ULN2003 2 IN1 4 IN2 5 IN3 3 IN4
Arduino Mega <==> Slider Potentiometer A0 to A7 1 to 8
Arduino Mega <==> Hall Sensors D32 to D39 1 to 8
Arduino <==> TTP229 <==> TM1637 46 CLK CLK 47 SDO SDO
Step 14: Arduino MEGA Firmware
Main Controller Firmware
Arduino Mega will act as the controller interface which senses the actuators and sends MIDI signals to the Arduino Micro (MIDI Device).
Download the Arduino Mega Firmware given below and upload it to the Arduino Mega.
- Extract the Arduino Mega Firmware compressed file.
- Pull Arduino Micro pin16 (MOSI) low and connect the Arduino Micro to the Computer via USB cable.
- Arduino Micro will detected as USB Serial Device and act as Arduino Serial.
- Flash the Arduino Mega Firmware in the main controller via Arduino Micro.
Arduino libraries used:
NOTE: To put Arduino Micro into MIDI Device mode pull the reset pin of Arduino Micro low.
Step 15: And We're DONE !!
You're finally done! Here's how the final product should look and work like.
Step 16: Please VOTE !
If you like this project, please vote for the "Instrument" Contest.
Really much appreciated! I hope you guys enjoyed the project!
Grand Prize in the
Instrument Contest
14 Comments
Question 2 years ago
What software did you use to to the wiring schematics?
2 years ago
create a making video. that would be awesome!!
2 years ago
I would love to see a video of it in action! It looks fantastic
Reply 2 years ago
Here is a video of my version from 2015. https://vimeo.com/171612791
Reply 2 years ago
Thank You. And it is on the way, will update it soon.
2 years ago
Is this a working design? I don't see a video, and the non-rendered disks are missing magnets.
Reply 2 years ago
Reply 2 years ago
Yes, this is completely working. And Sphere magnets are not the part of the build. So those are not included in those images. As they are used, in order to make the beats. So you can easily find them in video with great snapping sound. I hope you would love it.
2 years ago
Super Cute!
Reply 2 years ago
Thank You :)
2 years ago
Nice design. I do not see a standard MIDI port. Could this be made to output standard MIDI?
Reply 2 years ago
Thank you. And I haven't thought about a MIDI port, but will let you know if I can incorporate in this design.
2 years ago
Awesome! This reminds me of a 4 channel "soup-can" sequencer I made from a toy motor and a soup can that sent control voltage and gate signals to a pre-midi analog synth.
Reply 2 years ago
Thank You Sir :) I hope we can get some more inputs from such an experienced person like you, to improve this device for the community.
