Introduction: Mini Indoor Herb Garden
A few days ago, it was Earth day, and I think it's a good time to plant, so I've decided to build mini indoor herb garden. There are various ways to plant herbs, but i want to reuse plastic containers as recycling. It's very easy and inexpensive, but it looks great.
Step 1: What You Need
Materials : :
- Starter herbs as many as you want (be sure that they all fit in your container, and I recommend you to get them from local Farmers' Market)
- Potting soil
- Small plastic containers of some sort (any kind of and any size of)
- Big plastic container for plate
- String or yarn
- Wooden sticks from chopstick or popsicle stick (to make herbs name label) - optional
- A piece of cardboard (size:3 X 2cm for each herb) - optional
- Used coffee grounds - optional
Tools : :
- Double-sided tape or hot glue
- Scissors
- Awl or some thing that makes holes in things
- Water-based pen - optional
Step 2: Make a Hole
Make holes at the bottom of the container using your awl to drain water from soil.
Step 3: Wrapping String
Attach the tape on the whole outside of the container.
Wrap string on the taped container. When you start wrapping string, make room at the very edge of the container to untie the string.(There is a video instruction to help you to understand)
(Using glue: apply glue on the side of the containers and begin wrapping string around outside of the containers. All steps are pretty same with using double-sided tape)
Wrapping string on the side of plastic container from Michelle Min on Vimeo.
Step 4: Mix Soil
Mix soil with used coffee grounds at the ration of nine to one.(used coffee grounds have effect of fertilizer for your herbs)
Step 5: Prepare the Herbs to Plant
Take herbs out of the existing container, and remove the soil from the herbs gently because it might damage the root of herbs.
Step 6: Transplanting
Plant herbs into the middle of the container, and cover with the mixed soil(step 4).
Then, gently press the soil to release any air pocket.
Step 7: Making Name Label
Take your cardboard piece(3.5X2cm) and write down the name of the herb on it with water-based pen. ( I got the cardboard from the coffee holder of my favorite cafe)
Then, take your stick(make sure the length of the stick. I recommend to have double length of the container).
Attach the double-sided tape on one side of it, and wrap the string or yarn whatever you'd like on the tape. It's better make a room to attach the name label at the end of the stick.
Now you can attach the label on the top of the stick and poke the name label in front of the herb.
Step 8: Make a Plate for Your Herbs
Take the bigger container to make a plate. It is used salad plastic container, so we need to cut the lid and make two plates.
Then, do the same thing(step 3). Attach the double-sided tape on the each side of the container and wrap the string or yarn on it.
Place your herbs on the plate,.
Step 9: Enjoy!
Watch yours grow. Enjoy your herbs and tea!
I just baked "Rosemary herb cookies" from my mini garden for my classmates. Isn't that awesome?
Finalist in the
Garden Contest
14 Comments
9 years ago on Introduction
Awesome!!! Like the ideas for my herbs garden.
10 years ago on Introduction
Really cute idea! I love unique and creative ways to reuse things instead of just sending them to the recycle bin. Do you have a recipe 'instructable' for the rosemary cookies? They look wonderful!
11 years ago on Introduction
I liked string/yarn wrapping idea.. I will do the same over my (cheap) plastic pots..
12 years ago on Introduction
I like this idea a lot, and thought I could use some of the (what seems like) millions of tin cans I seem to have around here, instead of the plastic containers as I am really going off using plastic when I can.
Reply 12 years ago on Introduction
You can "go off using" plastic all you want, but plastic won't rust and then poison your plants/soil. Spme plastics may leach into your soil a bit, but tin is a bad idea, perhaps you might want to use some ceramics.
Re-using plastic that has already been used won't hurt the environment or use more fossil fuels. It actually has the opposite effect, when you can re-use and reduce consumption.
Reply 11 years ago on Introduction
Rust is quite natural - even in natural soil. Is this such a big an issue? I'm just curious really :)
This is a wonderful concept. But is the tape and string important, or just for looks?
Thank you for the comment. It's not important to do have the tape and string. As you know, it's just for good looking.
ok, thank you
I'm a tea drinker, so I don't have any coffee grounds. Would tea leaves also work?
Of course. It works well. Used tea leaves can be used as nitrogenous fertilizer for the any plants.
Love the string idea to pretty it up. Thanks for sharing this one. I've wanted to grow some on my kitchen sill and have yet to do it.
Whats the best way to get these plants to grow indoors? I dont really have any natural light.
The best way I recommend is to put the plants next to the window with sun and fresh wind. But as you mentioned, you don't have any natural light, so try to put your plants under any light at least 16 hours per day continuously. The most important thing you should do for them is to air out often. If you have time, bring yours to out of your place and try to take fresh air with it. I hope my comment helps you. Thank you.
