Introduction: Modern Ceiling LED Lamp
Hello everyone! Today we're gonna be making ceiling lamp using LED strips. As you can see from the top pictures, I first created my design using a CAD program and then I made it in real life, following my drawings. I decided to make it symmetrical (is is, although it seems slanted), but of course you're free to change the design to your own taste if you want :)
If we only exclude the cost of tools, black cardboard and current transformers (which I already had), the whole project costed around 27€.
You will need AT LEAST (which means, without considering the thickness of the blade you'll use to cut the pieces, in an ideal world where no one makes mistakes and the wood is available in continuous strips):
- 2x2cm wood strips (at least 6.48 meters)
- 3x3cm wood strip (at least 65cm)
- 6x0,9cm wood strip (at least 82cm)
- 17x24cm wood board (any thickness, recommended 0,9 cm)
- 5 m white LEDs
- 220V AC in, 12V DC out, 4A transformer (preferably, 2 of them)
- Some length of wire
- Black cardboard
The main tools I used were a drill, a miter saw (allowing for 45° cuts), a scroll saw and some fine sandpaper (240). You may also need a few electrician's tools.
Step 1: Making a Plan
I first started making a plan on a CAD software. I recommend you to print the first or the second picture (the ones with all the dimensions), so you can easily follow the plan. In the first picture I decided to color code each different section of the lamp in order to make the drawing easier to read.
Note: dimensions are expressed in mm!
Step 2: Cutting Wood to Length
You may start to cut the wood to length. Follow carefully the plan of the previous step, making 45° cuts that will make the assembly process a lot easier. Don't forget that the drawing shows the length on the outside of each piece you'll need to cut, so make sure to align and orientate correctly your piece before proceeding with the cut.
Following the plan, you'll need:
- 2x2x32(outside) - 4 pieces (long sides of small rectangles)
- 2x2x25(outside) - 4 pieces (short sides of small rectangles)
- 2x2x70(outside) - 4 pieces (long sides of big rectangles)
- 2x2x35(oustide) - 4 pieces (short sides of big rectangles)
- 0.9x6x24(outside) - 2 pieces (long sides of wire box)
- 0.9x6x17(outside) - 2 pieces (short sides of wire box)
- 17x24x0.9 - 1 piece (lid of wire box)
- 3x3x12 - 4 pieces (suspension columns)
- 3x3x?? - 1 piece (hanging mechanism, check step 5!)
Step 3: Drilling Holes and Gluing
You can now assemble each rectangle and the wire box (sides and lid only), gluing everything together.
You also have to make a few holes for the wires. Drill a hole across the length of each suspension column (without coming out of the other side) and then a smaller hole on one side, its height depending on the rectangle you have to get to (each one needs power).
You'll have to drill holes in the wooden board too, that way you can fit a wire from inside of the box to connect the LEDs.
Once you've inserted the wires in the holes, you can glue the suspension columns to the wire box and then the rectangles to the columns. Make sure the correct distances are respected and double check that each rectangle is nice and flat :)
Step 4: Mounting and Connecting LEDs
Since I'm so bad at making boxes, I decided to run a strip of black cardboard along the edge of the wire box, unintentionally making it look a lot nicer imho!
I then placed the LEDs along the inside of each rectangle (except between the columns). I made a few welds to join the LEDs to the wires and the wires to the transformers. I decided to put two different transformers because I liked the idea of being able to decide how many LEDs to turn on. The first button in my room turns on the small rectangles (creating a bright but not annoying light) the second one turns on the big rectangles (which are considerably brighter). Turn on both of them and it's instant noon!
Step 5: Fixing to the Ceiling
Unfortunately I didn't make a photo of the mounting mechanism, but I have drawn a scheme. The 3x3 cm wood strip has to be cut to length in order to fit perfectly inside the box as shown. You then have to make 2 holes in the middle of the box such that you can put two black screws (which will camouflage with the black cardboard) right in the center of the strip. You can then mount the 3x3 strip on the ceiling using 2 long screws and 2 fischer wall plugs and only then align the whole lamp to the 3x3 strip and put the black screws in!
Step 6: Done!
The ceiling lamp is now complete! Have fun building it and let me know if you make one :D
Don't forget to check out my other projects too! <3
Grand Prize in the
LED Strip Speed Challenge
4 People Made This Project!
- MarcosD4 made it!
- hasofbah made it!
- Tolga SerefK made it!
- АлексейС46 made it!
71 Comments
2 years ago
This is SO stunning. I love the simple lines :)
Reply 2 years ago
Thanks for your prompt and honest reply. Thinking about your idea of placing the strip on the top, I believe the best would be looking down. Of course depending on where and what for you need the light for. Generally, it is to get the most out of it. Indirect ceiling reflected light... well, it would make the lamp making process simpler. Would it be practical? Depends on the lumens and spread of the light. Thank you Fahrenheit. Keep calm and carry on.
Reply 1 year ago
Two switches and two strips?
Reply 2 years ago
Thank you <3
Question 2 years ago
Hi, great project!
I want to achieve the same but in a ~150cm diameter circle, any suggestions/links? I can't find a good way to form the circle :/
Answer 2 years ago
Hi, at work we make this sort of light with an aluminium kit, stretched ceiling and a home made PCB. This one is 120cm diameter.
Reply 2 years ago
This is a nice piece of a lamp. Where do you buy the aluminum kit? Do they come in different sizes? What is a PCB? Thanks.
Reply 1 year ago
You can buy aluminum channel for LED's from Aliexpress. Here are some examples: https://www.aliexpress.com/wholesale?catId=0&initiative_id=AS_20210104050304&SearchText=led+channel
Reply 2 years ago
The kit comes from a french company, C L I P S O. The PCBs are the aluminium boards where the LEDs circuits are.
Reply 1 year ago
The easiest way is to cut it from a sheet of cabinet grade plywood. Other than that you would need to glue pieces together then cut them. The latter method would be difficult even for an experienced carpenter.
Answer 2 years ago
I'm sorry, I didn't get the question. Do you want to specifically make a circle or you want to fit a lamp like mine in a 150cm diameter circle? In the second case, my lamp is actually about 120cm long
Reply 2 years ago
I want to specifically form a circle and lay LED strip inside. Yours is a great project though!
Reply 2 years ago
Uh, ok! Mmhh well, a wooden circle is a pretty hard task. You could start with a flat board and cut a big circle with a router attached to a compass, or you could approximate the circle with a polygon. Otherwise, you could use a deformable material like aluminum and shape it (not sure what tools are required) :) good luck anyway xD
Reply 1 year ago
Another way to create a circle from a straight board is to cut kerfs 3/4 of the way through the material. That will allow the material to bend. Not easy to do and not easy to make it look nice as the kerfs will show but they could be filled with something like automotive body fill or maybe expoxy resin.
Reply 2 years ago
Thanks for the reply, I'll let you know if I ever do it!
Reply 2 years ago
I've used premade picture frames, decorative mirror frames, and even car parts. Anything old can be made new again.
Reply 2 years ago
FYI this is the style of section I'd like to create in a circle
Reply 2 years ago
You can make the circle with a table saw - Metal L brackets-12 clamps- 4’x 4’ plywood . Screw at least 12 L brackets into the plywood to form your circle. Now cut your wood into 1/8 “ wide strips. Bend these strips around the L brackets clamping them as you go. Now apply glue to the second strip and add it to the first releasing each clamp and replacing it as you go. By the time you finish the forth strip your wood circle will be 1/2” wide. Now take
Bailing wire and small spacer blocks to tighten up any wood strips that are not pulled tight by twisting the bailing wire with pliers.
Reply 2 years ago
So laminate the thinner strips layer by layer. Could use thicker ones on the outside to create the channel like in this pic? Thanks!
Reply 2 years ago
Im not sure you want to point the light strips down. The original rectangular design put the strips on the inside edge , I do believe. It may also have a thin acrylic strip that covers the leds.
