Introduction: Modular Origami Swan
HISTORY
3D Modular Origami/Block Folding/Golden Venture Origami/Chinese Paperfolding is a branch of origami where the piece is not made out of one singular piece of paper, but made with many pieces, each folded the same way. It became popularized in the 1990s, when illegal Chinese immigrants aboard a ship called "The Golden Venture" tried to smuggle into America cleanly and quietly. Each of these Chinese immigrants (about 300 in total) had paid $5,000 and promised an additional $30,000 to be brought to America. Unfortunately for them, they were quickly caught and brought to jail to be detained and later deported. Many of the immigrants sought to soothe their troubles through creative expression. In prison, these immigrants created beautiful and elegant sculptures using everything from magazine pages to toilet paper. The pieces they created, specifically birds, are known as "Freedom Birds". Today, around 30 people from the Golden Venture are living in the US.
DESCRIPTION
This form of origami is absolutely stunning. Each sculpture consists of dozens and dozens of triangular-shaped pieces, but from afar it seems to be one rippling structure. The reason it can stay together is because of the ingenious structural components.
But bear in mind; this kind of origami is very time consuming! Don't expect to finish a sculpture in 30 minutes or so. Depending on how many pieces you need or how big the sculpture is, it can take anywhere from one hour to more than a week!
I've been making modular origami sculptures for three years now. The design I am going to show you is an adapted version of a modular swan that I created myself. It is very pretty and certainly an eye-catcher. It's not hard to make, is essentially free, and will surely impress!
DESCRIPTION
Step 1: Materials
The most important thing you need?
For this Instructable, I'll be using regular white computer paper, with colored paper to accent certain areas.
Optional:
- Paper! (A4 size, 7 or so sheets for this 'ible)
Optional:
- Glue/Mod Podge - Though this style of origami doesn't require any glue whatsoever, glue helps keep weaker structures together (like the neck), as well as glossier papers (like magazine covers).
- Scissors - You can cut the paper with scissors if you'd like. I'm used to creasing and ripping them, but scissors are far more accurate and probably won't result in torn-off pieces.
Step 2: Cutting the Paper
Each piece of A4 size paper (computer paper) yields 32 rectangles, which you can fold into 32 triangles.
This swan requires 215 pieces! 215/32 = 6.7, so you will need seven sheets of paper.
To cut the paper into the right size, fold the paper in half five times width-wise.
Each rectangle is 1/32 the size of a regular piece of paper.
Step 3: Making the Pieces
I highly recommend looking at the pictures first, it's easier to learn from the images than to only read the directions. If you don't understand something, read the directions and try again.
A blue line represents where to fold it. The arrows point you in the direction of the fold.
To begin with, take one of your rectangles.
1. Fold it in half length-wise.
2. Fold it in half width-wise.
3. Unfold the width-wise fold.
You should now have a rectangle folded in half with a crease in the middle.
4. For this step, line up the top of the rectangle (the folded side) to the center crease.
5. Repeat with the other side.
You should now have a pentagon-shaped piece of paper, with the two sides meeting in the center.
6. Flip the piece over.
7. Take the bottom rectangle on the left side. Take the furthest left edge and line it up with the slope of the triangle.
8. Crease the tip. You should now have a triangle.
9. Repeat on the other side.
You should now have a piece that resembles a diamond.
10. Tuck the bottom flaps in by pulling them up as far as they will go. Crease it.
11. Fold it in half.
You should now have a triangle!
Step 4: Anatomy of the Triangle and Stacking
ANATOMY
Before you stack pieces, you have to understand the anatomy of a triangle.
A triangle has two pockets and two points. Each point fits inside a pocket.
When you stack, you are building it in one line, so the two points of one piece fit into the two pockets of another piece.
When you're building, one point will go into the pocket of one piece, but the other point will go into the pocket of another piece.
STACKING
I chose to stack my pieces in increments of 10, but you can do more if you'd like.
As you make the pieces, it's helpful to stack them. This helps to open up the pockets to make the structure stronger, as well as helps you count how many pieces you have. Stacking pieces opens up the pockets, allowing for stronger structures. Though it's technically not necessary, I highly recommend it as it will keep your structure together and give you an easier time building.
To stack, slot the two points of one triangle into the two pockets of another triangle. Keep going for a few pieces, and once they expand in size, take the unopened triangles from the end and add them to the front. This way, you have a stick of fully opened triangles.
To take the triangles out of the stack, simply put your thumb right under the first triangle and push up. Once you've got the hang of it, you can take triangles off in seconds.
STACKING
Step 5: First and Second Layer: 40 Pieces
The first two layers of the swan is probably the hardest. This is on account of that there isn't a structure yet, so there isn't anything to build off of. But, once you get past the first two layers, it's smooth sailing.
To start, we're going to make twenty pairs of pieces. Because this is the first layer, we're going to invert the pieces to create a "stand" when the swan is completed. So, instead of building them all the same way, we will be turning one of the pieces over.
To make an inverted pair, take two triangles. In the pictures attached, the white represents the first triangle, and the blue represents the second triangle. Take your first triangle, and hold it so the slopes face front. Take your second triangle and flip it over, so you see the bottom parts of the triangle. Slot one point into one pocket. Repeat nineteen times!
Next, we're going to slot the twenty pairs together to make a ring. Build it on a flat surface to ensure it won't break. Slot the other point of the top triangle of a pair into the pocket of another triangle, and repeat until ten pairs have been used. We make the rings out of ten pieces twice instead of twenty pieces once because the pieces tend to curl. Repeat the process again so you have two rings of ten. From here, join the two rings together by slotting one point from one ring into the pocket of the other ring. Once finished, take the last point and slot it into the final pocket to create a ring. From here, carefully flip the piece over. Be very gentle as the ring will be very weak and may break!
Step 6: Third and Fourth Layers: 40 Pieces
Once you add the third and fourth layers, things will be a lot easier! With the addition of the third layer, the structure can be picked up, thrown around, etc. and still hold its shape.
The third layer is rather simple; instead of inverting the pieces, just slide them on like you did when you were stacking! The difference, however, is that instead of sliding two points from one piece onto two pockets from a second piece, you slide two points from two different triangles onto the pockets of one triangle. Once you've got one piece on, complete the layer by adding more pieces until the ring is full.
Once the ring is full, you can move on to the fourth layer. The fourth layer is the same as the third layer; keep adding on pieces to make a full ring just as before, with the pieces facing the same way.
When you've finished the third and fourth layer, turn the ring over again.
Step 7: Fifth and Sixth Layers: 40 Pieces
The fifth and sixth layers are the visible "body" of the swan. The pieces of the fifth and sixth layers also go in the same direction, no inverting whatsoever!
Because we flipped the structure over, we don't need to worry about inverting. Just add pieces on like you've been doing for the third and fourth layers! Add twenty pieces to the top of the fourth layer to create your fifth layer. From here, we have some "bodybuilding" to do!
Once you've added the fifth layer, flip the structure over again. Take both of your thumbs and gently press on the second layer as you pull the fifth layer up with your other fingers. Be very careful as not to rip any pieces! Do this slowly and gently. Once the second layer is lower than or about the same height as the fifth layer, wrap one hand around the piece and squeeze it. Hold it as though you are holding an ice cream cone, and even out the the build.
You should know have a structure that can stand on its own!
From here, add on another layer as you did with the third, fourth, and fifth layers. Stack it right on top of the fifth layer and go all around. This is the second-to-last full layer that you will be doing. It is also the last layer of the body that you will have to build.
Step 8: Wings: 72 Pieces (36 Each)
The wings of the swan are composed of 36 pieces each (8+7+6+5+4+3+2+1). The wings start out from the bottom with eight pieces, and are made of 8 "layers". It diminishes from 8 pieces to 7 pieces to 6 pieces, and so on and so forth.
To begin with, start from any two points from your sixth layer. Add eight pieces to form the beginning of your wing. These eight pieces represent your seventh layer. We are now going to form the eighth layer. Skip the first point from the seventh layer and add another piece. Add six more pieces (for a total of seven). Keep skipping the first point, adding on a layer with one less piece from the layer before to finish the wing.
To create space between the first wing and the second wing, take two pieces and invert them. Place them next to your seventh layer. Now, place your eight pieces next to the two inverted pieces, and repeat the process again.
Step 9: Neck and Tail: 20 + 3 Pieces
The neck and tail are the final details on the swan! After this step, you're pretty much done!
NECK
Go back to the two inverted pieces that you put in between the two wings earlier. Take two sticks of ten and connect them to create one stick of twenty. Take the bottom of the stick, skip one point on the inverted pieces, and place it in the middle. Push it in to make sure that it isn't loose or wobbly. From here, you can curl the neck to make it more "swan-like". I prefer to use one hand and curl down, making half a heart with my fingers. An S-shape is usually more common when making the neck.
TAIL
When you were making the wings earlier, you left off after the additional 8 pieces. This means that there is still a gap on the other side! Turn the swan around to go to this side. Add two pieces on top of the four points, and add one piece on top to make the tail.
And you're done!
NECK
TAIL
And you're done!
Step 10: Additional Gluing
Some parts of the swan are very weak and may be susceptible to breaking. To prevent this, some glue can be added to keep these pieces in place.
Glue is not needed for the structure to stay together. It can be used as a "supplement" to make sure that the swan is safe in transport, or if you just want it to be more secure overall.
The neck is a very weak part of the swan because it is not connected to any other part. You can add glue at parts of the neck, at the base, etc. To add glue, simply squeeze a dot (not any more, or it will come out!) in the pockets of the triangle and use it as you normally would.
Step 11: Finished!
Sit back and admire your handiwork!
This swan is a perfect addition to any coffee table or display case, and is a definite conversation piece, especially when they find out you made it yourself!
So, what do you think? Should I make more 'ibles about Modular Origami? :3
![3rd Epilog Challenge](https://content.instructables.com/FRS/YU09/HD4VPZ34/FRSYU09HD4VPZ34.png?auto=webp&frame=1&width=320)
