Introduction: Nature's Tech Hand
If we observe closely to the Mother Nature, we will feel that Nature is the most creative artist, it's technology is amazing ! Thus My motto to create this art piece to give this message -
Human should blend Technologies with Nature within the "Limit" !
Where the Mother Nature's Hand can create beautiful arts !
Thus i thought i should create a Hand holding a Technological Cube blended with Nature's Art !
For this i was having lots of waste tree branches in my Backyard / Garden. So i decided to clean this up in a creative way !
If you have some waste tree branches then don't throw it, you can create this awesome Nature' Hand !
Surprise Point to be Noted : I have used some Giloy Plants (Tinospora cordifolia) climber, i managed to leave its other part near to the land and after finishing the project i will place this Art in a garden and apply some soil under the side. Then after some time our Nature's Tech Hand will grow and will look an awesome Greenery's Hand holding a Technological Cube !
So are you ready to create it ! Let's Nature It !!!
Waste Tree Branches
Jute or Burlap Rope
Step 1: Creating Basic Structure...
First try to choose some big size and one piece tree branches, if you got an oval shape then it will be better, else we have to create that shape !
Next for base you may take a stand, or table or whatever you want, it will be temporary !
Then try to overlap some big tree branches together and make an Oval shape !
Then after creating the basic Palm structure, we have to select some branches for Thumb and Index Finger !
Don't worry most of the tree branches looks like thumb and fingers shape if you observe closely then you will find it !
Have Patience ! You are going to create an awesome art piece !!!
Step 2: Creating the Hand Shape...
Take Burlap Rope or Jute Rope to make our art piece ECO-Friendly and tie some tree branches with our selected Thumb and Index Finger, and add some branches for Middle, Ring and Little Fingers too !
and repeat the same steps to make more dense, use Big to Small tree branches for Thumb to Little Finger respectively as shown in photos and videos !
Step 3: Creating Wrist (Stand) Structure !
Take some Heavy and Big Tree Branches according to the size of our Big Hand Art Piece ! Then take four of them and tie using Burlap or Jute Rope ! It must be strong enough to take load of the Hand Art Piece ! It will be the Wrist of the Hand Art Piece !!!
Step 4: Creating Finger Bend Lines !
Now we have to create Finger Bend Lines to be more creative, For this you can use Giloy Plant (Tinospora cordifolia) Climber. Take some of them and cut according to the thickness of Thumb to Little Finger correspondingly !
Step 5: Creating Muscles With Bone !! Making More Dense !
Now after creating the basic structure, the hand bones needs to fill with muscles, to do this take some small and straight sticks, tree branches and tie them like given in photos !
Then insert in the empty places like inside, or overlap together ! Use your creativity and measurement according to the Palm, Thumb, and Fingers' shape !
Step 6: Creating Muscles, Veins and Additional Boundaries !!
Have patience !!!
Slowly slowly you will see a hand shape, although sometimes you may see a different shape in it ! But Don't worry you after completing you will never regret !
Now choose some long tree branches, try to choose some flexible branches and insert inside the hand shape where you see some gaps, and try to overlap them together ! Maintain the direction of the branches according to the palm, fingers and whole hand !
So it is being heavy now and after adding more tree branches it will be more heavy ! To deal with it use small buckets or chairs to hold this structure ! You should not put or create on the pre designed stand else first it will be not comfortable to design on that height ! and second you may not move it properly !
Step 7: Detailing by Seeing Our Own Hand !
See your hand, and try to observe your hand from each side and make the shape of holding a cube ! Then Use your creativity to make more dense and design it to make more closer to look like a Hand Holding a cube ! As seen in videos we have created wrist structure, I was alone at that time so i was having trouble to hold the whole structure alone but you have to take someone's help to put Hand Art Piece on the top of the Wrist (Stand) !
After putting the Hand Structure, it may be the tree branches scattered or misplaced and because of that the shape of the Hand may change so use some more small branches to cover the empty area !
Step 8: Creating Hand's Lines (Heart, Fate, Life, Sun Etc.)
After adding many tree branches and filling flexible, thick, thin, long small etc. branches I have used Giloy Plant (Tinospora cordifolia) to create Hand's Lines (Heart, Fate, Life, Sun etc.) so it will look more better. You can see these lines clearly in the photos !
Now you can see in the photos it is looking like a Hand shape structure which is about to holding a Cube which we are going to design ! Let's Create It !!!
Step 9: Creating the EcoTech Cube ! Supplies
Now after creating the Hand Sculpture, It's time to create the cube which will hold by our Hand Art Piece !
For that you will need some tools, Small Tree Branches and Some Giloy Plant (Tinospora cordifolia) (as used previously)
1. Iron wire
2. Thread / Jute / Burlap
3. Waste Circuit Boards - 2 atleast
4. Plyer / Other tool to tight the wire
5. Holder
6. Electric Wire
7. Bulb
8. Hammer
Step 10: Creating the EcoTech Cube ! Step 1
First take 12-13 branches with apx equal size and tie them one by one using Iron wire / thread and make a Cube like in photos !
Then in next you will need to attach the circuit boards !
Step 11: Creating the EcoTech Cube ! Step 2
Take the circuit boards and attach them inside the cube facing outside the circuit !
To blend with the nature we will use Giloy Plant (Tinospora cordifolia) to overlap, so try to overlap them on the circuit like in photos i did ! You may use other circuits, like i have used waste keyboard inside circuit flap !
Step 12: Creating the EcoTech Cube ! Step 3
Now take a holder, electric wire and a bulb, hang it inside the cube properly see the lamp's beauty ! You may be more creative, but remember blending with nature is more important and here nature is more important so i have used a little technological effect !
Step 13: Creating the EcoTech Cube ! Step 4
Take a small plant which can be insert inside the cube carefully then attach the cube diagonally between Thumb and Index Finger ! It may be a little tricky but if you do it carefully then it will look like awesome ! You can see how out Hand is now holding the EcoTech Cube !!!
Step 14: Final Touch and Voila !!!
Now connect the wire and switch on the bulb ! and Voila see you have created your awesome Hand Art Piece holding the Technological Cube !
How creatively The Mother Nature's Hand is Holding the Technology...
Recycle - Reduce - Reuse - Recreate
Thank You
