Introduction: New York City Street Scene in Tinkercad
I absolutely adore big cities and New York has been at the top of my list for years. So, I decided to mix some creativity into that love and create this scene from scratch.
Step 1: Google Maps
The very first step I took was searching for a street I wanted to model in New York City. I knew I wanted the Empire State Building in the picture, so I looked around and decided on the simple street in the picture.
Looking in the top left hand corner, you can see I'm at 1 W 33rd St.
Step 2: Roads
First, I laid my foundation by building the roads. Because the street I want to model begins at an intersection, I took two squares from the basic shapes provided by Tinkercad and shaped them into a long T. I didn't worry too much about how long they were because I can always reshape the roads later. I grouped the two and changed the color to black.
Step 3: Sidewalks
To make the sidewalks, I made rectangles with a width of 2 mm and the length of the road it was on. To make the curved corners, I overlapped the 2 strips of sidewalks. I grabbed a cylinder from the shapes bar and adjusted the shaped until they perfectly lined up. Then, I grouped everything and changed the color to a grayish tan.
To make the curve smoother, I changed the cylinder's sides all the way up to 64.
Step 4: Buildings
To make the buildings, started with a simple rectangle. I then set the workplane on top of that rectangle and pressed Ctrl d, then pressed d again. This created an exact replica of that box on top of the original. I estimated the size of each box and changed their colors. I did so as many times as needed, looking at the street on Google Maps as a guide.
Step 5: Storefronts
After I had all the basic shapes in place, I started on the details, making the storefronts first.
I moved the workplane to the face of the building. I resized squares from the shape bar and spaced them out evenly along the front of the building to map out the stores.
I turned the square into a hold and made a duplicate of that square. I grouped the hole and the wall to create an indent in the wall. I changed the color of the duplicate to whatever I needed and placed that square directly into the indent.
To make the doors, I used the same method. I grabbed a square, turned it into a hole, and made a duplicate. This time, though, I grouped the first hole to the colored block inside the indent that I just made. Then, I duplicated the second hole. I grouped the second hole to the actual wall of the building to create a deeper indent. I changed the size and color of the third duplicate to match what I needed and slid it into the indent.
Using this method, I created the storefronts. I also resized and colored more shapes and text based on the picture on Google Maps to make the stores I needed.
Step 6: Windows
I used the same method of creating holes and duplicates from the last step to make the windows.
I found that the quickest way to make the numerous windows on a building was to group the windows in one row and use the duplicate button the stack them on top of each other. Then, I grouped all those rows, so all the windows were grouped, and continued with my method.
To make the color for most windows, I overlapped a layer of transparent blue on top of a layer of black.
Step 7: Road Details
For the details on the road, I simply resized squares from the shape bar and colored them white.
Step 8: And... Repeat
I continued to use simple shapes and Google Maps as a guide to create this small piece of New York City.
![Tinkercad Student Design Contest](https://content.instructables.com/FWW/X5XP/KAZD46ND/FWWX5XPKAZD46ND.jpg?auto=webp&crop=1240%2C600&frame=1&width=320)
