Introduction: Night Lamp Made by the Old Tape Cassettes
Hello guys......
Here I had made a Night lampusing the old tape cassettes.
This Lamp is very Easy to make..
I hope you like it.
Follow us on ...
YouTube - https://www.youtube.com/channel/UCBBRzYNzCALewaf20rg6dWg?view_as=subscriber
Facebook - https://www.facebook.com/kedar1705/
Step 1: Tools and Requirements
Requirements -
- 12 V LED s * 2
- Zip Ties * As required
- 12 V DC Adapter * 1
- Tape cassettes * 36
- 12 V female pin * 1
- Strong cable with two wires * As required
Tools -
Expect to the cassettes all other tools & requirements you will get in Hardware & Electronics store.
And all these will get you at cheaper price in stores than online...
So I would suggest to buy from stores...
SO LET'S START........!
Step 2: Step to Build the Walls of Lamp
Actually this lamp is cubic shaped...
So first we have to make walls of the cube using tape cassettes...
Use lamp walls using 6 cassettes and assemble casets by zip ties...
make 6 cassettes walls....
Step 3: Building the Cassettes Cube
Now build the CUBE using the CASSETTE WALLS WHICH WE MADE...
Build the cube as shown in Images given above...
Step 4: Connecting & Mounting the LED S
STEPS -
- First remove some LED wire insulation cover.
- Then mount them inside the cube of cassettes.
- Connect the wires in the parallel connection.
- Take the wire cable.
- Insert the cable in the corner of cube as shown.
- Zip the zip ties to wire as shown to hold the cable in the cube.
- Connect cable terminals to the terminals of LED s.
- Cut the excess part of zip ties.
Step 5: The Power Supply
Connect the 12 V female pin to the another end of black cable...
And connect the 12 V adapter to the female pin...
Step 6: See This Project on Youtube
YOU CAN SEE MY PROJECT ON YOUTUBE....!
Follow us on -
THANK YOU.................!
Reuse Contest
2 Comments
2 years ago
This is cool. Have you ever worked with steel zip ties?
Reply 2 years ago
No, I hadn't.
But I will try it soon...
Thanks for your feedback & suggestion.
