Introduction: Niskin Bottle
In oceanography it is of importance to take in-situ water samples. This tutorial will explain how to make a Niskin bottle. A Niskin bottle allows us take a water sample from a specific depth.
One practical use for the Niskin bottle could be finding the thermocline. In order to do this we would take various water samples from different depths, measure their temperature and hence find the approximate depth at which we have a (relatively speaking) high drop in temperature.
The way the Niskin bottle works had to be adapted a little in order to make it at a low cost and high viability. The here presented bottle uses two ropes: one holds on to the actual bottle and the other activates it at the wanted depth. Once the activation rope is pulled the bottle closes and the water is trapped inside.
Also check out this video. Here you can see professional Niskin bottles in action.
Necessary Tools
- power drill
- drill bit 4mm
- drill bit 3mm
- sand paper 100 - 200
- file
- cutter (utility knife)
- scissors
Material
- PVC tube approximately 33cm long (inner diameter: 85mm, outer: 90mm)
- 2 gummy plungers (max diameter 105mm)
- 400mm chain that weighs around 300g or more
- 50 cm of latex tubing
- plastic splint 5mm in diameter
- about 60m of rope to take water samples of up to 30m of depth
Step 1: Cutting and Polishing of PVC Tube
polish thoroughly the cut borders of primary tube. The uniformity of the surface defines later the quality of the closing mechanism
Step 2: Slot
At one end of the primary tube create a slot. This will serve as a fixed point for the cable tie. (This end of the primary tube is the part pointing downwards)
Step 3: Plug Preparation
Cut a 45º angle in the ends of the plugs. (This is done in order to facilitate the closing process of the bottle, see also Step 13)
Step 4: Drill the Plugs
With a power drill place a hole in both plugs. Use a 4mm drill bit.
Step 5: Inserting Latex Rubber Tubing
Put the latex tubing in one of the plugs as indicated in the photo. The piece of rope is merely a way of helping to get the tubing threaded through the small hole.
Step 6: Locked Off First Plug
This is how the plug should look like after the latex tubing was pulled through and tied off with a knot. In the photo we can see only one side. The other side will be done after having passed the latex tubing through the PVC tube. See also photo 10.
Step 7: Drill Two Holes for the Upper Holding Loop
Drill two holes (in the opposite end as shown in Step 2) using a 4mm drill bit. Insert the rope that will be used to attach the bottle. The here shown slot is not necessary.
Step 8: Attach Lateral Loops Two Lower End of the Body Tube
Attach ropes with a cable tie as shown in the photo. This is the bottom part of the Niskin bottle.
Step 9: Attach Weight
Attach chain to the rope prepared in photo 8. The chain will serve as weight so that the bottle sinks vertically.
Step 10: Tightening of Latex Hose
With two persons: tie the second plug to the latex tubing. Important: the tubing has to be taut !
Step 11: Attach Lock Off Loops
Tie a rope to the ends of the latex tubing as show in the photo.
Step 12: Prepare Activation Splint
with a 3mm drill bit place a hole in the activation splint and tie a piece of rope (30cm) to it as shown.
Step 13: Ready to Go
This is how the closing mechanism is prepared.
