Introduction: Old Jeans to Stylin' Beanie
In this Ible you will turn your old set of jeans thatdo not fit and/or are mutilated beyond repair into a fantastical new(old) beanie.
Step 1: Beanie Sections
THe first thing we will do is to measure the circumference of your cranium, and by using complexe math we will determine a formula relating to us your actual brain capacity... or not. But we will use the diameter of your skull. Only to determine the diameter of your hat. And then we will divide that number by the number of sections you want to be in your hat. The more sections are in your hat the rounder it will be. I chose six because it is a nice even number and that is what most hats are made of. For me the diameter of my cranium was About 24 inches so that means(in case you can't do such complex math as this) that i will have four inch wide sections. you will also measure from the top of your head to were you want the hat to end and this will be the height of your beanie. (doh) so now we draw our form, we want the sides to be curved so that our hat is not a hexangular whatever. just trust me it is easier to have the curved sides. After we draw our pattern go back and add half an inch to ensure that your sections are the size you want when they get sewn together. Cut it out.
Step 2: Cutting Your Jeans
Be sure that you left room for the sewing. Notice that i left a notch i the tip of my paper iron this is to ensure that the top of your hat does not have a "hump". Trace the pattern onto the jeans as many times as you have sections. Then cut them out including the notch and the half inch.
Step 3: SEWING!!!!!
Put the sections together outside facing each other(meaning the side that you want seen you put towards each other. Sew one side together backstitching at the start and end to ensure that it doesn't unravel, Backstitching means that you stitch forward then back then forward again. do this to all of your sections until you come to where you must sew it together to create a complete article of clothing! Mwahahahahahahahahahahahaha..a... ha.. ha uh never mind. Oh sew it all together. Anyway you will have a mostly finished hat. One thing that you might consider is to iron the stitches flat before you sew on the next one.
Then your pretty much finished...........
Step 4: But There's More
this is the beach bum me after i bleached and washed the hat so it looks definitively better than it did before
