Introduction: Origami Display Shelf
I enjoy making origami! However, I did not have a good place to display the origami I made. They were scattered around the house on bookshelves and my drawers.
I needed something that can be flexible so to fit origamis of different sizes. It also needed to be adjustable from time to time so I can change what to display without take down the whole structure. Ideally it should be lightweight and space saving. It also needed to be made made of some material I can handle easily and independently.
Materials
- Styrofoam boards
- Tape (Duct tapes, optional Decorative washi tape)
- Skewer sticks ( I used metal as well as bamboo ones, whichever I can find at ho
- Sewing pins
- Nails (2)
Tools
- Cutting knife
- Ruler
- Hammer
Step 1: Structure: Location, Design, Pre-setup
Decide where you want to set up your structure in the house. Find the studs in the wall and hammer in the nails. Measure and record the desired size of the structure on this wall.
Step 2: Paint the Styrofoam
Paint all sides of the styrofoam pieces. You will want to paint the tops and sides first, wait for them to dry, then paint the bottoms.
Step 3: Cut the Styrofoam As Designed
Given the layout of the shelf as designed earlier, cut the styrofoam with a cutting knife.
Trim all of the similar (same-colored on the diagram) Styrofoam pieces to the same length.
Step 4: Assemble: Add Metal Skewers
Stick 2 metal skewers in the sides of each of the holding pieces (yellow). Leave some portion of the skewer hanging out.
Step 5: Assemble: Attach Styrofoam Sides
Use the ends of the metal skewers to attach the holding pieces to the side pieces (blue in design).
Step 6: Assemble: Attach Styrofoam Top/Bottom Supports
Use the pins to attach the styrofoam cover supports to the top and bottom of the shelf (red in design).
Step 7: Assemble: Wrap Duct Tape
Wrap duct tape around the perimeter of the shelf for extra support.
Step 8: Assemble: Deco With Washi Tape
Add washi tape around the holding segments (top, middle, and bottom) of the shelf.
Step 9: Setup: Paint Backgrounds
Paint, draw, or make your own backgrounds for each piece of origami.
Step 10: Setup: Arrange Origami
Arrange the origami on the backgrounds.
Consider origami and backgrounds that go together in an interesting setting, for example, the sword goes well with the cube cross sections, the magic balls go well with the black-and-white shapes, and the bird goes well with the telephone wires.
Step 11: Setup: Pin the Background Paper
Add styrofoam blocks as needed for edges. Pin everything together.
This step helps to steady our styrofoam structure as well.
Step 12: Setup: Repeat With More Backgrounds
Add more backgrounds, styrofoam supports, and pins.
Step 13: Finish!
We added koi fish and lily pads on the side of the shelf.
It took us a while to gradually fill this shelf! A fun time to see the collection grow!
Step 14: Credits
I used the following Instructables for the papercraft:
https://www.instructables.com/Twist-Top-Gift-Box/
https://www.instructables.com/Origami-Mystery-Cupb...
https://www.instructables.com/Ninja-Sword-Cuts-Mat...
https://www.instructables.com/Puzzle-Locked-Paper-...
https://www.instructables.com/Jumping-Origami-Frog...
https://www.instructables.com/How-to-Make-an-Origa...
Thank you to the Instructables Community!
