Introduction: Outdoor Candy Lighted Cane Cane Decorations
Outdoor Quality Candy Cane Christmas Decorations
Gather the items needed to make your decorated Candy Canes.
For each candy cane decoration you will wan to make you need the following:
1 Plastic Candy Cane about 36 inches tall
Decorative items of your choice, my choice was:
Plastic Mistletoe with ribbon and bell (The mistletoe was dual sided!
That meant I needed 1 mistletoe for every 2 candy canes! It also had the red ribbon and bell attached.)
Holly Leaves (I bought a stem of leaves, enough for 3-4 candy canes)
White Poinsettia (I bought a stem of flowers, enough for 12 candy canes.)
Plastic Snowflake (this one is about 4 inches around. There were 10 in a box. Enough for 10 candy canes!)
Card of Red Christmas Bows (18 on the card I bought)
You will also need a
glue gun,
glue sticks (to match the gun you have)
Scissors
The whole project takes about 5 to 10 minutes per candy cane. You can make enough to line your entire yard in just a few hours.
I purchased everything except the scissors and glue gun and glue sticks at the local dollar store.
The Candy Canes were $1.00 each,
The flowers were $1.00 per stem with holly leaves and 12 flowers on the stem.
The holly leaves had 12 stems, each with 1 to 3 holly leaf groups on them. (I consider a grouping as the 3 leaves still together.)
The mistletoe with bell cost $1.00 each, and each one had the mistletoe on each side, so I had double mistletoe by removing one bunch of mistletoe and re-gluing the leaves and berries to be sure it would not fall apart.
The card of Christmas Bows were $1.00 for 18 bows.
Total cost for 1 dozen Decorated Candy Canes: $16.00
Putting your project together
Gather all your supplies to your work table
1.Prepare the holly leaves by removing them from the leaf stem. You may want to snip the holly into individual leaves. If your holly looks fine intact, you may choose to leave it as is and glue it in as a complete 3 leaf section.
2.Prepare the Mistletoe ( Yours may not need anything done to it.)
3.Cut the ribbon to the length you want your ribbon and bell to be making sure it will show beneath the mistletoe and holly leaves.
4.Glue Holly Leaves to the back of the mistletoe, then the mistletoe to the ribbon and bell, and finally glue toe mistletoe bunch to the candy cane about 9 inches down from the curve.
5.Glue Holly Leaves to the back of the flower, just as you did the mistletoe and glue onto the candy cane above the Mistletoe.
6. Add any other decorations needed to cover up the cane between the mistletoe and flower, or just for your own liking.
7.Finally glue the snowflake in place, just above the flower. The snowflake serves as a place to rest the Christmas light strand. It is at the top of the decorations for this purpose.
The finished Candy Cane
When you have completed your candy cane, you can either drill holes in the ground, then screw your candy cane into them, or attach your candy cane to a wooden stake in order to make the candy cane more sturdy in areas that need a little extra help.
Place them about 5 or 6 feet apart down the sidewalk or in your yard.
String the Christmas tree lights across them by using the snowflake to hold the strand. If you need to attach a second strand, just plug it into the first, and plan your candy canes so you can use the candy cane to hide the extra wires. Use white yarn to tie the wires out of sight, down the candy cane.
glue gun,
Scissors
Step 1: Prepare Holly Leaves
Step 2: Prepare the Mistletoe
1.Prepare the Mistletoe ( Yours may not need anything done to it.)
If you need to trim the mistletoe do it now. It needs to be flat and any pieces that can fall off attached tightly with glue so they are not going to come off in weather.
Step 3: Cut Ribbon and Bell to Fit the Mistletoe
1.Cut the ribbon to the length you want your ribbon and bell to be making sure it will show beneath the mistletoe and holly leaves.
Step 4: Glue Holly Leaves to Back of Mistletoe
1.Glue Holly Leaves to the back of the mistletoe, then the mistletoe to the ribbon and bell, and finally glue toe mistletoe bunch to the candy cane about 9 inches down from the curve.
Step 5: Glue Holly Leaves to Back of Flower
1.Glue Holly Leaves to the back of the flower, just as you did the mistletoe then glue the flower and holly leaves onto the candy cane above the Mistletoe. Be sure to leave room so the flower and mistletoe are clearly viable and one does not hide the other.
Step 6: Add Additional Deocration As Desired
Add any other decorations needed to cover up the cane between the mistletoe and flower, or just for your own liking. In this case I added a red bow between the mistletoe and poinsettia to cover the candy cane.
Step 7: Glue Snowflake to Candy Cane
Step 8: Place Your Candy Canes Outside Where You Can Enjoy Them
Step 9: Finished With Lights
Here is a view of this simple decorative project in darkness with the Christmas lights on. Have fun and you can do any kind of decor that suits your fancy. Remember, reach the sky. Your project is only limited to your own imagination. Let your creative juices flow and see what you come up with!
