Introduction: Paracord Bracelet
Step 1:
Use a lighter and burn the end of the cord and flatten it so the string inside doesn't come out.
Step 2:
Measure 8 feet of cord. (If you are doing two colors, measure 4 feet of each and burn the ends together so it is about 8 feet long, but still using the same method).
Step 3:
Get a relatively small buckle and grip the two ends together and put them through the buckle together.
Step 4:
Pull the cord through, but leave a small loop at the end to put the cord through. Once you have done that, pull it so it is tight.
Step 5:
Put the other buckle on and wrap it around your wrist leaving space.
Step 6:
It is hard to put into words so do what the photos show. What I can tell you is to, on the end going down, wrap it over and inside the "loop" you see.
Step 7:
Continue to do that, but on the other side each time.
Step 8:
When you reach the end, cut the excess cord leaving a tiny bit of cord, and after that, melt it with the orange part of the flame.
1 Person Made This Project!
- spartan.hargreaves made it!
8 years ago
Good job! I'll probably update this one and provide better pictures and other stuff
