Introduction: Perfect Smoked Brisket in an Electric Smoker
Who doesn't love a nicely marinated and perfectly cooked beef brisket? I know for a fact that I absolutely love it and would eat it 24/7.
I'm going to show you a recipe that is so simple that a person who can't even cut an onion would be able to do it with ease, it gets perfectly cooked and the meat is cooked to perfection.
The recipe makes 12-16 servings (could be one serving depending if you can stop eating this piece of heaven!)
Ingredients for the Marinade
- 2 tablespoons of chili powder (spice level is whatever you would like it to be, from mild to hot)
- 1 tablespoon of coarse salt
- 1 tablespoon of brown sugar (trust me don't use traditional granulated sugar, BAD mistake!)
- 2 teaspoons of garlic salt
- 2 teaspoons of garlic salt (I tend to add a tiny bit more but it's all a personal preference with seasonings)
- 1 Teaspoon of cumin
- ½ a teaspoon of cayenne pepper (again you can add a bit more or a bit less of this, it's a bit of a mix and match)
- 1 tablespoon of dried oregano (I recommend using homegrown as it tastes so much fresher)
Instructions for Using the Marinade
This is very simple using the amazing seasonings, all you do is blend the above ingredients together (have a little taste first and see if you like it, otherwise you won't like the meat at all!)
Step 1: Choosing Good Brisket
The most important part of a good brisket is buying a great piece of meat. As with most meats you want the most tender as possible, the more tender the better.
A tip I'm going to give you today is to hold the brisket and balance it over your hands, the more the meat bends the better the meat will be and the more tender it will be.
Also, look for a brisket with a thick fat layer, the higher fat levels will help the meat stay as moist as possible during the smoking process, I recommend finding a brisket that's about 10 pounds in weight (4.5 KG)
Step 2: Marinade
Get your tasty marinade ready and massage it on to the meat. Although some people may tell you that this can be done 2-4 hours before the smoking process, I've found that the beef will have a much better flavor if you leave it to sit over-night.
I recommend putting the marinade on the brisket the day before you plan to smoke it. To finish up, once you have completed rubbing the marinade all over the meat wrap it in aluminum foil and chuck it in the refrigerator overnight.
Step 3: Smoke With Wood
Now here comes the part we all want to know how! Remove your brisket about 2 hours before you ready to start up the smoker so that it can rise up to room temperature.
Some outdoor professionals use this time to inject a marinade into the meat, but I personally just like to let the smoke flavor the inside of the meat.
Fill the wood chip box with mesquite, hickory, apple or cherry wood chips (this is again up to personal preference, I usually go with hickory). Charcoal can also be used, but wood chips are preferred as they provide better flavor to the meat.
Step 4: Smoke Brisket
Now comes the even funner part, letting it cook! If you're smoking with a Masterbuilt 40 electric smoker (quite a popular electric smoker you, can read review of masterbuilt 40 here ) then preheat it to 225 degrees F (about 107 Celsius) and set the internal meat temperature to 190 degrees F (87 C) Stick the temperature probe into the thickest part of our brisket and place it on one of the racks in our cooker.
Press start on the smoker. When the probe reaches 190 degrees (87 C) the digital smoker will stop cooking and turn on warm mode to keep the brisket warm until you want to dig in and eat it!
Now keep in mind other smokers will have different setting so refer to your manual, the key thing about the cooking process though is getting the brisket to 190 degrees F (107 C) Following this guide will make smoking a brisket in an electric smoker easy!
Image Source: flickr
17 Comments
1 year ago on Step 4
I just love this. Amazing!
2 years ago on Step 4
I have 7.47 pound flat cut brisket. Using an electric smoker. Looking for temp and how long to smoke. Thanks for any help
4 years ago on Step 4
Pospin-there is simply not enough pertinent information here in your how-to article to yield a tender, juicy and delicious brisket unfortunately. If you or any other beginner smokers out there want a good article to read before smoking brisket for the first time I highly recommend watching some youtube videos or reading some articles by Aaron Franklin of Franklin BBQ in Austin, TX or an article by meat smoking expert Jess Pryles. Check out links below. Even though a lot of their methods and advise refers to indirect or reverse indirect smoking on a charcoal smoker, they will give you the knowledge and ideas to master your own tasty, tender and delicious brisket on your first or second brisket smoke ever! Hope this info and sources provided help you and any other beginner smokers achieve a tender, juicy, tasty and fall apart Brisket!
https://jesspryles.com/recipe/how-to-smoke-a-brisk...
Question 5 years ago on Introduction
I have a 4 pound brisket. What is the cooking time?
Answer 4 years ago
Rule of thumb is 50min-1hr per pound of meat. Do not go off time for best results in the end, best to wait till internal temperature reaches 200-205 degrees then do a probe test in a few spots on the brisket with a long wooden skewer, if the skewer slides into the meat and resembles sticking skewer into a jar of peanut butter then you can pull your brisket. wrap brisket in pink butcher paper or aluminum foil or both and let rest on the counter or in a cooler for 1-2 hr's, best results will be with a 2hr rest. That is when your brisket will be done. Unfortunately if you want a tender and delicious result in the end you simply cannot solely rely on time cooked. Hope that helps! even a year later.
5 years ago
can someone give me an estimated idea on how long it would take to smoke a 14 pound brisket in an electric smoker please? Trying to figure out what time I will need to start it so it will be done in time.
Reply 4 years ago
Question 5 years ago on Step 4
what about a pan with water and how much air should be allowed in
5 years ago
I guess passionate about writing means plagiarizing from the manufacturer's website? Or maybe they are plagiarizing you?
https://www.charbroil.com/learn/smoke-brisket-electric-smoker/
6 years ago
Thanks for the info. I have a 12 pounder for Mother's Day.
6 years ago
I have a Masterbuilt Electric Smoker and I'm having problems getting my hickory wood chips to smoke in the chip bin. I was told not to soak them first. Last time I had to use a lighter to get the chips going. any ideas?
Reply 6 years ago
Clean your thermostat in the back of the unit. All electric smokers have that issue.Try using a cast iron chip pan. They retain heat much better. Also, try removing the rack, and place the chip pan directly on the element.
6 years ago
What tempurature should the electric smoker be set on? I have a Masterbuilt Smoker.
Reply 6 years ago
Set you Masterbuilt smoker to 225 - 230 degrees
6 years ago
What temperature should the electric smoker be set on? I have a Masterbuilt Smoker.
6 years ago
Smoked brisket is the best. I always wanted to learn how to make my own. Thanks for sharing the tutorial.
Reply 6 years ago
Thanks for your comment :)
