Introduction: Piano Clavinova - Keyboard Sustain Pedal Repair
The sustain pedal of my Clavinova CLP 120 doesn't work anymore... after "only" 13 years!
Let's have a look and repair it
Supplies:
Philips screwdriver
Step 1: Tilt Your Piano
Tilt your piano and remove the dust!!
Then use your screw driver to remove the 8 screws (4 are only reachable through holes in the plate)
Step 2: Inside the Pedal Box: Fixing the Switch
remove 2 little black screws to withdraw the pedal itself
the switch is a "Rubber Contact Membrane" or "Carbon Tactile Keys" or "rubber-coated switch"
FYI a comprehensive study here : http://www.comdes.nl/PDF/GTC/Keypad-Design-Guide.p...
solution 1/ I swapped the grey switch from the middle pedal to the sustain pedal: It didn't solve my problem... but maybe yours?
solution 2/ I simply added a corrugated board between the pedal and the switch! It works again!
solution 3/ you could try to re-paste the conductive circuit with a silver conductive glue
Beware that cheap conductive glue has low amount of silver (if any) and won't really work
Step 3: Clavinova Clp120/clp130 Service Manual
here the official documentation from Yamaha, it could be helpful
Step 4: Humor
We cannot accept that our piano pedal may malfunctionning... imagine the danger, if you have a piano-car
