Introduction: Play Christmas Music on an ESP32-C6 Using ChatGPT (No Amplifier Needed!)
AI has completely changed how we approach electronics. Tasks that once felt intimidating — like programming microcontrollers, generating code, or building embedded projects — are now accessible to anyone.
In this project, we’ll use an ESP32-C6 DevKit, a simple 4Ω speaker, and a single capacitor to play Christmas songs generated entirely by ChatGPT. No amplifier, no advanced circuitry, and zero manual coding required.
If you’re looking for a fun, quick, holiday-themed electronics build, this one is perfect.
- ESP32C6 DEVKIT M-1 ( or any similar)
- 4 Ohm 3 Watt speaker
- 22uF Electrolytic Capacitor
- Jumper Wires
- USB Cable for programming (Type C)
Step 1: Watch the Video
Before you begin, watch the full build tutorial so you understand the hardware layout, the ChatGPT workflow, and how everything comes together:
https://youtu.be/lIHwOk6v8J0?si=jx0KX06r_crlcE9s
Step 2: Wiring
We are using:
- ESP32-C6 DevKit
- 4 Ω 3W speaker
- 22 µF electrolytic capacitor (in series)
- GPIO13 for audio
- GND for return
Wiring:
This single capacitor prevents large current spikes that would otherwise damage the microcontroller.
Step 3: Why the Capacitor Is Important?
3.1 What Happens Without the Capacitor?
If you connected a 4 Ω speaker directly to a 3.3 V GPIO pin:
Using Ohm’s Law:
I = V / R
I = 3.3 V / 4 Ω = 0.825 A (825 mA)
825 mA is far beyond what the ESP32-C6 GPIO can supply.
Reference values:
- Typical safe GPIO current: ~20 mA
- Typical absolute maximum per pin: ~40 mA (ESP32 family guideline)
So the raw current the speaker would draw is:
- 41× higher than a safe GPIO current
- 20× higher than the absolute maximum
Conclusion:
A speaker cannot be directly connected to a GPIO pin without protection.
3.2 What the 22 µF Capacitor Actually Does
Putting a capacitor in series with the speaker creates a high-pass filter.
This blocks DC and greatly reduces low-frequency current spikes.
Cutoff frequency formula (first-order high-pass):
Where:
R = 4 Ω
C = 22 µF = 22 × 10⁻⁶ F
Plugging in values:
So around 1.8 kHz, low frequencies are attenuated heavily.
This means:
- DC = fully blocked (0 Hz → infinite impedance)
- Low tones = greatly reduced current
- Safe enough for hobby-level PWM audio demos
3.3 Example Current Calculations With the Capacitor
The capacitor impedance depends on frequency:
Example at 200 Hz (well below cutoff):
Xc ≈ 36.2 Ω
Z ≈ 36.4 Ω
I ≈ 3.3 V / 36.4 Ω ≈ 0.091 A (91 mA)
Still high, but much lower than the 825 mA DC case.
Example at 1 kHz:
Xc ≈ 7.23 Ω
Z ≈ 8.27 Ω
I ≈ 3.3 V / 8.27 Ω ≈ 0.40 A (400 mA)
But real hardware never reaches these theoretical numbers because:
- The ESP32-C6 output driver has internal resistance
- PWM creates lower average current
- Speaker impedance rises above DC rating depending on frequency
- The 3.3 V regulator limits available current
- The GPIO pin cannot actually source these levels
- So in practice, the output is audible but quiet, exactly what we want.
Step 4: Generating the Code With ChatGPT
Paste the following prompt into ChatGPT to generate the complete Arduino sketch:
Step 5: ChatGPT Code
In this project, all of the firmware was generated by ChatGPT based on the prompt provided earlier.
Here is the exact code ChatGPT produced for my build.
IMPORTANT:
Your AI-generated code may look slightly different depending on the version of ChatGPT or the prompt used — but it will follow the same structure.
Step 6: Install All Required Libraries and ESP32 Board Support
Before your code can compile, your Arduino IDE must be properly configured.
6.1 Install ESP32 Board Support (ESP32-C6)
- Open Arduino IDE
- Go to File → Preferences
- Find the field: Additional Boards Manager URLs
- Add the official Espressif URL:
- Click OK
- Go to Tools → Board → Boards Manager
- Search: esp32
- Install: esp32 by Espressif Systems
This will add support for:
- ESP32
- ESP32-S2
- ESP32-S3
- ESP32-C3
- ESP32-C6 (what we need)
After installation, select the board:
Tools → Board → ESP32 → ESP32-C6 Dev Module
6.2 Install Required Libraries
Your AI-generated code relies on these Arduino libraries:
Required Library: Adafruit NeoPixel
- Open Tools → Manage Libraries
- Search: Adafruit NeoPixel
- Install: Adafruit NeoPixel by Adafruit
This library is needed for the single WS2812 RGB LED.
Optional Library Notes
Depending on your AI code, ChatGPT may also include:
- #include <Arduino.h> (built-in)
- #include <driver/...> (should NOT be included — if AI adds LEDC drivers, remove them because we're using tone() only)
If your code uses these by mistake, re-prompt ChatGPT to:
“Remove any LEDC APIs and only use tone()/noTone().”
6.3 Select the Correct Port
Go to:
Tools → Port → (your ESP32-C6 COM / USB device)
If you do not see it, try:
- unplug/replug USB-C cable
- use a known-good data cable
- press the BOOT button while plugging in
Step 7: Compile and Upload the Firmware
Once everything is set up:
- Open Arduino IDE
- Paste the AI-generated .ino code into a new sketch
- Select your board:
- Tools → Board → ESP32 → ESP32-C6 Dev Module
- Select the correct COM/USB port
- Click Upload
Arduino IDE will:
- compile the code
- convert it into a binary
- flash it to your ESP32-C6
- automatically reboot the board
If everything is installed correctly, your ESP32-C6 should begin playing a melody and running LED animations immediately.
If You Get Errors (This Is Normal!)
AI-generated code isn’t always perfect on the first try.
If you run into errors — just copy the exact error message and tell it to ChatGPT.
Most of the time, AI will regenerate the corrected code within seconds.
Examples of what to say:
- “ChatGPT, this code fails because ‘Adafruit_NeoPixel’ was not declared. Please fix it.”
- “tone() is not recognized by ESP32-C6. Adjust the code accordingly.”
- “This variable is undeclared. Fix the function where it appears.”
90% of errors can be fixed simply by showing the compiler message to the AI.
This is the entire point of the project:
the AI becomes your firmware assistant, and you don’t need to understand every line of code to keep going.
Step 8: Enjoy the Music + Light Show
Once the code successfully uploads, your ESP32-C6 should immediately start:
- Playing the first Christmas carol through the speaker
- Animating the WS2812 (NeoPixel) according to the selected LED pattern
- Responding to the BOOT button (GPIO9) to skip songs
- Looping through all 5 public-domain Christmas songs
- Entering a candle-flicker idle mode between songs
The audio won’t be loud — that’s expected.
Remember, this is direct PWM drive through a capacitor, not a powered amplifier.
Still, it's surprising how clear the tones can be with such a small setup.
If you see lights + hear music → Congratulations! It works.
Step 9: Conclusion
This project demonstrates just how far AI has come in lowering the barrier to entry for electronics.
With a simple ESP32-C6, a 4 Ω speaker, and a 22 µF capacitor, you can build a fully functional music and LED effects system without writing a single line of code by hand.
AI handled:
- generating the full Arduino sketch
- structuring melodies and timing
- building LED animations
- adding button interactions
- correcting compile errors when asked
All you had to do was provide the prompt, wire the hardware, and upload the code.
If you’re new to electronics or coming back after a long break, there has never been a better time to start. Tools like ChatGPT now act as a real firmware assistant — helping you build, debug, and experiment faster than ever.
Feel free to expand on this build with more songs, better LEDs, a real amplifier, or even Wi-Fi controls.
Let your imagination take over — the AI will follow.
