Introduction: PlayStation 5 Controller Holder
I made a PlayStation 5 controller holder to prevent losing your controller. The holder will be hooked on to the Play Station 5.
To make this 3D design I used Autodesk Inventor
Step 1: Sketch
First you're going to start with a rectangle that 5.4 inches high and 3.5 inches long.
Step 2: Extrude
Now extrude the rectangle by 0.21 inches thick.
Step 3: Sketch and Dimension
Now you want to start a ketch on the rectangle and add a straight line with the dimensions of 1.5 inches high.
Step 4: Bend Part
Now your going to want to finish sketch and bend part. Then click on the line you just sketched and bend it to 0.1 inches.
Step 5: Sketch and Extrude
Start a new sketch and add another rectangle on top, but with the same length not height make the height 3 inches tall. And extrusion the same as well.
Step 6: Bend Part
Now bend the new rectangle to 90 degrees and 0 inches.
Step 7: Sketch and Bend Part
Now add a sketch and draw a straight line across the back of the rectangle you just bent, and dimension it to 2.2 inches high. Then finally finish sketch and bend part to 90 degrees and 0 inches.
Step 8: Finished Product
And now you're finished and made a 3D printed PlayStation 5 controller holder.
