Introduction: Power Adaptor
I use an old computer power supply to make a lab power adaptor. This power adaptor have fixed and variable voltage. A 5 Volt fix voltage and optional 3.3, 12 and -5 volt with high current outputs and short circuit protection.
Part list:
- Crocodile clips
- Binding posts (terminals)
- Galvanised plate
- Conectors
- Wire connector
- LED
- 1K resistor
- Switch
- Spongebob assistant (optional)
Step 1: Panel
make your favorite panel, I use galvanised plate and yellow paper. Design and draw panel with computer software and print on paper and paste on galvanised plate. Then drill holes for terminal, LED and switch.
Step 2: Binding Posts
- Screw the binding posts into their corresponding holes
- Attach the nut on the back as shown on pictures
Step 3: Switch and LED
Mount switch and LED on the panel.
Use 1K ohm resistor and solder to LED and notice the polarities.
Connect and solder black and green wire to the switch
Step 4: Power Supply
- Open up the power supply unit
- Seperate red, orange, green, white, yellow and 3 black wire
- Cut other wires
- Make sure wire not connected together
Wire Colors:
- Red: 5V
- Yellow: 12V
- Orange: 3.3V
- White: -5V
- Green: Power on
- Black: GND
The color of wires may be different, see this link or use a voltmeter.
Step 5: Connecting Wires
Solder orange, yellow, black and white wire and connect to binding posts as shown
Step 6: Crocodile Clips
- Use Crocodile clips for fixed 5v
- Connect crocodile wires to red and black
- Use wire tape
Step 7: Hot Glue
Use hot glue to fix LED, switch and wire
Step 8: Wire for Others Voltage
This link is a greatEncyclopedia of ATX to Bench Power Supply Conversion, thanks to russ_hensel
https://www.instructables.com/id/Encyclopedia-of-ATX-to-Bench-Power-Supply-Conversi/
Reuse Contest
11 Comments
7 years ago
what wires connect to the led and how?
Reply 7 years ago
Like this:
Reply 7 years ago
Thanks. I was kinda confused bc I saw a brown wire in one of your pictures connected to the LED and was thinking where it came from.
8 years ago on Introduction
LOL the spongebob assistant is very funny. Nice that you have some humor in your instructable.
Thanks alot dear friend
Good job, this is a great instructable. Thanks!
thank you dear friend
Just a note to let you know I have added this instructable to the collection:
>> https://www.instructables.com/id/Encyclopedia-of-A...
Take a look at about 70 different approaches to this project. This topic is one of the most
popular ( to write ) of all instructables.
thanks for attention
it is great and useful
I add to my post
I love how Sponge Bob always seems to help you out!
;) yes, he is genius
