Introduction: Put Music Onto Your Xbox 360 Hardrive
Figure out how to put music onto your xbox 360 hardrive
Step 1: Cd
Press the eject button on your xbox/ xbox 360
then put in a CD or a CD you burned.
Press eject again to close it.
Step 2: Music
Now you can play your music on your xbox360.
If you want to be able to play your music while playing a game then press the rip CD button on the screen.
Step 3: Select Songs
Select all the songs you want onto your hardrive
press rip CD again then you can edit your songs
ex:Name
Artist
Album
28 Comments
8 years ago on Introduction
Get a CD-RW, use windows media player to burn your songs to the CD, rip to xbox and repeat
11 years ago on Introduction
Does it take the music permenently off the disc? or is like copy?
its a copy but i understand your confusion but my sister thought i would brake her cd when i said i was going to burn it.
13 years ago on Introduction
Is there any way to do this through an ipod?
Reply 11 years ago on Introduction
yeah connect your ipod through your usb cable
Reply 12 years ago on Introduction
yes, you plug the usb cable from your ipod to the 360 and press the xbox menu button and got to music press select music then press portable device and choose the song! :)
that doesn't work for me :( even after I did the update, the unprotected AACs dont work.
There is a program called switch file sound converter it's a free trial but you can downgrade via uninstall and you can convert music files try that and make sure you properaly format your burnted disks
i don't havexbox live so i don't have any updates so can't help you there srry
oh, ok, its been really bothering me, especially because I followed microsofts directions EXACTLY
but you can clear system cache to remove all updates to see if it works because i had to do it with mine
I figured it out, I had to convert them to unprotected AAC in itunes
Only problem with that is, it won't let you put the songs onto the xbox hardrive.
so...
The instructable should have been on how to do this with an iPod because most people have an iPod instead of having a million Compact Discs.
or just get a ps3 and use a flash drive and import it into the music folder
well how do you do it with movies??
wow this is easy hahahaha well to me anyways
13 years ago on Step 3
Yea, the problem with burnt CD's is that the xbox won't read the files correctly. If you have a normal CD of a band, the xbox will rip the CD just fine.
