Introduction: Quick and Easy Miniature Pancakes
I've always loved pancakes, and tiny foods. So, what better way to enjoy breakfast than to combine the two together! You can serve these tiny pancakes for breakfast, a quick snack, or even a dessert if you want to get creative. These delicious, fluffy pancakes only have four ingredients and are sure to bring a bit of magic to your meal!
For these pancakes, the recipe I used is from Betty Crocker Kitchens. The ingredients are:
- 2 tablespoons vegetable oil
- 2 large eggs
- 1 cup of milk
- 2 cups of Original Bisquick™ Baking Mix
You also need a medium-sized bowl, a spatula, a pan, and some cooking spray (butter works fine).
Step 1: Adding in the Ingredients
Mix all of the ingredients together in the bowl. Luckily, the order you add ingredients doesn't matter.
Step 2: Mixing the Batter
Mix the batter together until it's smooth. Make sure to scrape the sides of bowl to get any extra batter.
Step 3: Preparing the Pan
Grease the pan with cooking spray (or butter), then heat it to medium-high heat. You'll know it's hot enough to cook the pancakes when you flick a little water on the pan and it sizzles.
Step 4: Measuring Out the Right Amount
Take a teaspoon and fill it with batter. (This is to ensure all the pancakes are tiny and relatively the same size).
Step 5: Making the Pancakes
Drop the batter onto the pan, then fill again and drop several more. With my pan, the most comfortable amount of mini-pancakes I can fit is six.
Step 6: Flipping the Pancakes
After waiting until the edges lift up, (no more than 30 seconds), slide the spatula under the pancake and flip. Repeat for the rest of the pancakes.
Step 7: Putting Them Away
Once all the pancakes are fully cooked, put them on a plate. It's quicker to slide them right out of the pan.
Step 8: Finishing the Pancakes
Repeat pouring and flipping until you have the amount of pancakes you want, (or run out of batter, whichever comes first) then enjoy!
Step 9: Storing
If you have extra pancakes left, you can always store them in a Tupperware for a day or two (when they start to get soggy).
Big and Small Contest
