Introduction: RAISED Vegetable Bed With Storage Underneath
How to make a "raised up" raised vegetable bed with storage underneath .
In a small garden, space is always at a premium so here is how I have a simple idea to maximising the space.
Step 1: The Wooden Bed: Materials
Materials
Old bunk bed (slats)
Other wood will also be required
wooden crate
Old plastic shower curtain
Hollow fibre stuff used for quilting
Porous woven material , I used an old tarpaulin but have used builders bulk delivery bag
Screws
Wood preserver, .
wooden crate
Screws
Wood preserver, .
Step 2: Make Up the Raised Bed
- If the bed is complete then make up one bunk
-Put the wooden slatts in.
-Add the slats from the second bunk bed to make a more solid table.
NB I had to remove the slats from the webbing which joined them together
-Screw the slats in position
-Paint with preservative
Step 3: Raise to the Right Height
-I used an old crate to lift the bed higher from the ground to make it a better working height for me and provide more storge underneath.
-I made supports for each end of the bed to take the weight
-Remember to work out the working height which includes your containers
- If using just slats then add edging this is to keep the plastic sheet up at the edges and keep the water from draining away
Step 4: Waterproof Layer
-Lay plastic sheet on the bed
-Lay hollow fibre on top
Step 5: Porous Woven Layer
Put a layer of plastic woven sheeting on top , the water must be able to pass through into the layer below.
Step 6: Add Containers
Place boxes, containers on top and fill and sow or plant up
Vegetables grown on the raised bed
Mixed Salad
Mustard leaves,
Shallots,
Chard
Wintergreen cabbage
Cavolo kale
Carrots
Lambs lettuce,
Mixed Salad
Mustard leaves,
Shallots,
Chard
Wintergreen cabbage
Cavolo kale
Carrots
Lambs lettuce,
Step 7: Next Instructable
Plant protection ideas for raised veg bed
