Introduction: RC AMPHIBIUS MISSILE LAUNCHER WITH WIFI CAMERA
Making exciting toys while on holiday with the family is a very fun atmosphere. Having crazy ideas sometimes requires a high level of imagination. This time I will explain a little more about how to make a car that can run on land and in water equipped with a rocket launcher. Have fun.
Materials needed:
2 sheets of Impraboard
Enough glue gun
Enough aluminum foil
Colorful cables
Rc 5 channel pcb board
Mosquito trap PCB board
3 battries 3.7 volt 500 mah
Limit switches
Switch opener toys
10 ml syringe
2 dynamo gearboxes
1 can of spray paint
Styrofoam as needed
Enough plastic mica
Thin copper for antenna amplifier
0.2 pixel wifi camera
Required tools:
Electric soldering iron
Tin
Cable stripper
Isolation
Ruler
Scissors
Whiteboard marker
spirtus
Step 1:
1. Putting two gearboxes together with impraboard
2. Make fins on all wheels
3. Make the upper body from impraboard
4. Make a rocket or missile launcher from impraboard and 10 ml injection and 2
5. Add plastic mica sheets for the windows
6. Arrange the upper chain
Step 2:
1. Arranging the bottom circuit, adding the antenna tip with copper sheet
2. Make an antenna with a layer of aluminum foil
3. Add foam below
4. Setting the remote signal range with the transmitter
5.Install the wifi camera unit and battery in the upper body on the lower hood of the car
Step 3:
How a rocket or missile launcher amphibious car with a WiFi camera works:
Install the batteries in the three units in the car. The car remote control unit and the rocket launcher.
WiFi camera unit. Then connect the camera to WiFi on your cellphone with the FPV camera application. After that, run it as you like and good luck.
Robotics Contest
