REPAIR LOOSE DRYWALL ANCHORS
Introduction: REPAIR LOOSE DRYWALL ANCHORS
About: In my shop I have a name for hammer, saw, and plier. The saw is Tess, the hammer's Joe, and Glumdalclitch is the plier. Yes, I'm brillig, and my slithy toves still gyre and gimble in the wabe. With that, le…
Here is an easy fix for loose drywall anchors.
Step 1: TYPES OF ANCHORS
This quick fix will work on the straight in type of wall anchors in the first picture. It will not work on the ones that expand behind the walls.
Step 2: INSTALLING a WALL ANCHOR
Of the straight in types of wall anchors, this one is perhaps the most secure. With any of this type, installation is usually to poke a small hole and either tap or screw in the anchor.
Step 3: INSTALL THE REASON FOR THE ANCHOR
I'm showing a coat hook. This method can be used for any wall hanging for which an expandable anchor was NOT used: bathroom towel bars, toilet paper holders, pictures, or any type of hook like the one shown.
Step 4: JARFOLD, WE HAVE a PROBLEM
Oh, oh, the anchor has pulled out of the wall. What do we do?
Step 5: USE EXPANDABLE GLUE
Gorilla Glue and similar products expand when drying and is used a lot in furniture making for that reason: to get tighter joints. If you glob this stuff on the anchor and put the anchor back in the same hole (you might have to use some painter's tape to hold it in place) and let it dry....
Step 6: VOILA!
Let it dry overnight. Now you can hang something heavy on it.
Step 7: HOPE YOU FOUND THAT INFORMATIVE
Of course, if the hole is way beyond the ability of the glue to expand, or if the sheetrock is so damage a patch has to be made, or a host of other reasons this cannot be done, then you have to rethink the solution. My motto: I never have a PROBLEM, I only have a CHALLENGE!
Hope you enjoyed. Comments are always welcomed. I'll enter this in the STICK IT CONTEST and see what happens.
KJ
Stick It! Contest
Stick It! Contest
1 Person Made This Project!
  • Game Design: Student Design Challenge
  • For the Home Contest
  • Make It Bridge
    Make It Bridge
9 Comments
MikeS1024
MikeS1024
2 years ago
Spray a little water on the glue just before you put it in the hole and it will expand much more - a little like spray insulation on a much smaller scale.
Kink Jarfold
Kink Jarfold
Reply 2 years ago
This works on Gorilla Glue? As Spock would say: Fascinating.
MikeS1024
MikeS1024
Reply 2 years ago
Yes, that type of Gorilla glue expands to and follows moisture as it sets.
Naturecalls88
Naturecalls88
2 years ago
Going to try this but with a pencil holder the rubber slip around the tip grip kind glued in first as a reinforcement for the wall....see how it goes
Kink Jarfold
Kink Jarfold
Reply 2 years ago
I'm curious to see how that works. Add some pictures when and if it works.
gravityisweak
gravityisweak
4 years ago
I'll have to try this. My toilet paper roll doesnt want to stay stuck to the wall. It's good for normal use but changing the roll over time is what it hates. My thought was maybe mounting the roll to a small rectangle of wood and attaching the wood to a stud.
Kink Jarfold
Kink Jarfold
Reply 4 years ago
Hi, GIW, The TP holder is the first thing I tried this on. I used lots of Gorilla glue. Make sure you let it dry over night. I've also done the block of wood route, but I cut decorative 45s on each corner, routed the edge and stained it and made it look pretty. Good luck.
KJ
Thorondor95
Thorondor95
4 years ago
You broke my concentration at the end...
puddnheadwilson
puddnheadwilson
4 years ago on Step 7
Great solution for a perennial problem. Thanks for sharing!
