Introduction: Rainbow Glow Citrus Assembly
Have you ever seen a light that flashes various colors rather than one? I believe you haven't. It's the best night light you will ever obtain or purchased for your partner, friends, or your youngsters.😉
I made this component on "Tinkercad.com," it is easy to make.
Before you go to step 1
You'll need 3 10in wires,
1 Arduino Uno,
1 NeoPixel Ring 16, a 24,
And 1 Neopixel jewel
Step 1: Step 1: Connecting
To make the machine operate you will need to have 3 circuits/wires for the Arduino Uno and the Neopixel ring. It can be any color you want it to be. You will need to put 2 wire in the power source (5v & GND). Then you will need to put another wire on the Digital source (9). After this, put the first wire that is joined to the power source (5v) and put it in the 2 Neopixel rings and the Neopixel jewel power section. After that put, the second wire that's in the power source (GND) in the ground section in the 3 Neopixels and closing, put the wire in the Digital side (9), in the in sections in each of the Neopixels. If you are frustrated then view the images it will assist you.
Step 2: Step 2: Coding
After you get or make the pieces. You will want to start coding to get it to brighten up. If you don't understand how to code then you can use the code I have though if you know how to code and don't desire to use it then you build what you do best. It flashes bright like a light bulb and if you don't want anything to expose the components then you can 3d print something that is non-see-through but only the Neopixel Ring.
Step 3: Step 3: the Final Step
After you have put all the components together and wired the Neopixels and the Arduino Uno and code it all you have to do is start it and it will shine bright as a lamp.
I hoped you were interested in my presentation. Ask any question you have for me and share what you have invented.
Step 4: Video Clip
Here's a video clip on neopixels.
