Introduction: Raspberry Portable Pi Laptop
Hi guys! This is a really quick and easy project with a great outcome. The Portable Pi Laptop is a cost effective alternative to a standard laptop, it's great for developing software whilst on the go, it's easy to build and it's great fun!
Portability would generally be the main challenge with projects such as this; it can be difficult to get power off grid. However, in my case this is one hurdle which I am able to easily overcome; as with all of my other projects I have been using the PiJuice as an integrated battery module, which is able to provide all of the features you would ordinarily find in your laptop's powering system (complete with our revolutionary PiAnywhere technology – the best way to take your Pi off the grid!).
There's some great examples out there of other similar projects. Namely, the Pi-Top and the LapPi. These are both really cool designs and formed much of the inspiration for this project. I wanted to make something similar, but ideally, simpler and more portable. So I came up with this design. Comprised of just 5 parts, it merely involves plugging in each component and a tiny bit of configuration. So let's get started.
Step 1: Parts
Step 2: Assembly
The first stage of this build is to put together the hardware. The laser cut parts and a guide of how to put them together are available for pre-order from the Kickstarter page. Alternatively, if you have access to a laser cutter or even a jigsaw cutter you could easily build your own.
After that you'll need to solder two wires onto the screen so that it can receive power from the PiJuice. Solder a red wire to the +5V pad and a brown or black wire to GND pad. Ideally these two wires would have a double female connector on the end.
Then using, the plastic spacers, screw the Raspberry Pi to the chassis. Now take the HDMI cable and connect the Raspberry Pi to the HDMI screen. And the PiJuice simply connects to the GPIO on the Raspberry Pi
To power the screen take two wires and connect them to the 5V and GND breakout on the PiJuice.
The whole unit should now rest easily at a 45 degree angle. You may just want to check that it's wired up correctly so switch on the PiJuice and, if everything has gone to plan a green LED should light up on the screen.
Step 3: Software
For this I've used a standard Raspbian Image available for download from the Raspberry Pi website. You then need to write it to your blank SD card using your preferred SD imaging tool.
Now we just need to make a few configuration changes and then we're there. For this you can leave the SD card in your PC. Head to the root directory on the SD card and open up config.txt.
Find where it says "#hdmi_force_hotplug=1" and uncomment by removing the #.
Just bellow edit "#uncomment to force a specific hdmi mode" section so that it reads as in the picture. Save that file and exit. We've just set the resolution to fit the HDMI screen that we're using.
Now we need to make some changes so that the wireless mouse can run smoothly. Keeping the SD card in your PC open up the cmdline.txt file. To the end of the file, add the following text "usbhid.mousepoll=0" and save and exit.
Now plug in the SD card and boot up, plug in your wireless mouse dongle and your ready to go!
12 Comments
5 years ago
it is just awosome
6 years ago
How can you do this project without the PiJuicd
6 years ago
Hi, I've added your project to the "8 Impressive Raspberry Pi Laptops" Collection
This is the link If you are interested:
https://www.instructables.com/id/Awesome-DIY-Raspbe...
6 years ago
Outstanding!! I have always wanted to make or find a good computer for under $200.
6 years ago
6 years ago
I've been meaning to do something similar with an Android and then a Windows 8 tablet, but having the tablet joined with the keyboard so I can transport the whole thing like a single unit and use it in bed, on a chair and other places without having to put it on a desk unless there's one available. I've tried to figure a way to make a platform of sorts to hold the keyboard and the tablet together but I have no tools so I am looking for something already made that I can easily adapt.
I kinda forgot about it but your project kinda revived my interest on doing it. It is a nice instructable indeed.
7 years ago
I will try to make it thx from egypt
7 years ago on Introduction
RPi A+ and KB-Mouse dongle = No WiFi!!
7 years ago
Very cool, but I suggest a small keyboard so you could fit it in your pocket.
This is awesome! I'd love to see copies of your laser cut parts whenever you decide to release them. Best of luck with your Kickstarter!
Thanks tomatoskins! glad you liked it.
7 years ago
Need one badly!
