Remote Control for Lava 'mMotion Swing' Mounting Bracket
3,270
4
6
Introduction: Remote Control for Lava 'mMotion Swing' Mounting Bracket
My television is mounted on an fancy 'mMotion Swing' mounting bracket made by Sweedish 'People of Lava'. The mMotion Swing is motorized and by using it's remote control, I can bring my television into any angle between 0 degrees and 90 degrees (probably even more).
I have however had problems with the remote control being unstable. I have been changing batteries, cleaning the battery terminals, cleaning the PCB, tearing my hair out,.... nothing helped.
A replacement remote control is not terribly expensive (https://buylava.com/collections/other/products/mm...) but would be too easy, right? So I made a replacement remote control.
Step 1: Build Remote Control
The images above shows a simple proof-of-concept construction. This is what you will need:
  • Arduino (I used a Nano)
  • IR tx LED
  • 220Ohm resistor
  • Push button
  • 3 position switch
  • 9V battery
  • Battery connector
  • Some wires
  • An enclosure (e.g. a used jewel box like on the photo)
Step 2: Software
The software is very simple, and can be found here: https://github.com/LarsWH/arduinoLavaRc
It does however require a modified library as well, which can be found here: https://github.com/LarsWH/Arduino-IRremote
The software can be build with a standard Arduino IDE, but has been developed using Microsoft VisualStudio with the 'VisualMicro' plugin.
People of Lava have been kind enough to published the IR commands as a PDF here: http://www.peopleoflava.com/info/mMotion/IR%20Code. But unfortunately the instructions only partly workded for me.
These commands are the ones that did work for me:
  • Auto: RC5 code: 0x0C (as per the documentation)
  • In: RC5 extended code: 0x1B 0x5E (unlike the documentation)
  • Out: RC5 extended code: 0x1B 0x5F (unlike the documentation)
More information about the RC5 protocol here:
Step 3: For the Record...
Looking at the project now, it all seems very simple, but in fact it took many many hours of reverse engineering:
  • Building up a general-purpose IR monitor (arduino based) to record signals. In the end I did not really need this - just the oscilloscope
  • Capturing IR signals on oscilloscope, to learn that the Lava documentation must be wrong.
  • Getting the timing right. Especially a silence period of approx. 80ms between repeating signals seems important
  • Trying to do all the above with a semi defect Lava remote control, that only sometimes would output a signal.
  • Develop an extesion to the existing IR library in order to have support for 'RC5 extended'
Step 4: Build Into Box
Since this a very simple construction, there is no need for a PCB. The few wires can be soldered directly onto the Arduino Nano.
Fitting everything into the jewel box is a bit tricky, but doable. The used jewel box is a temporary solution (has been for many months now....), but my daughter thinks of it as her contribution to the project, so it stays like this a little while longer.
Step 5: Future Improvements
When I get around to it, I would like to make these improvements:
  • Range: Increase the IR LED output to get more range of usage. If the IR LED is driven more directly from the battery (controlled by a transistor), a higher current can be provided, and thus more light emitted.
  • Power on: Decrease the power-on time of the Arduino, so commands are sent without any noticeable delay. The current power-on delay is around 3s.
  • Buttons: Replace the current 1 switch + 1 button with 3 dedicated buttons
  • Enclosure: Something nicer than a used jewel box
Be the First to Share
    • Teach With Tinkercad Contest
    • Back to School: Student Design Challenge
    • Cheese Challenge
      Cheese Challenge
    6 Comments
    PETER
    PETER
    Question 6 months ago on Introduction
    HELLO
    Is LAVA mmotion remote 433MHZ or 866MHZ
    I am asking because I can buy an IR Remote code cloner quite cheaply. can it be used at all ??
    Provisional THANK YOU
    Peter
    LarsWH
    LarsWH
    Answer 6 months ago
    My Lava is neither. It is using infrared light (IR) like most ordinary remote controls (for e.g.: a TV)
    TomV139
    TomV139
    Question 1 year ago on Step 5
    Hi Lars, i also have this very nice TV swing and experience the same issues.
    before attempting to reapply your work i would like to ask if your swing is still functioning with your home made remote.
    LarsWH
    LarsWH
    Answer 1 year ago
    Hi Tom.
    Yes it is still working nicely.
    One improvement I would like to make though, is to add a LED to the top part, so I can indicates to the user when an IR transmission is ongoing. From experience I have learned that I have to keep the button pressed down for approx. 3s before the swing starts moving, but a bit more visible feedback would be nice.
    /Lars
    TomV139
    TomV139
    Reply 1 year ago
    thank you Lars. I just ordered 2 IR tx LEDs (880nm and 940nm) and 3 position switch (on/off/on). Will first make a test with a Arduino Uno. if i can get it to work will go for a nano with a casing :)
    LarsWH
    LarsWH
    Reply 1 year ago
    Good luck Tom. You probably want do try increasing the IR LED output (as I suggested in the original posting). I never got around to doing that, so I have to hold the remote fairly close to the IR receiver, for things to work.
