Remove Sharp Tin Can Rim
Introduction: Remove Sharp Tin Can Rim
How to remove the sharp inner ring from the inside of pull tab tin cans.
Step 1: Step One:
Take your can with the sharp inner ring and your smooth edge can opener and use the can opener on the can as if you are opening it. Be sure to go all the way around.
Step 2: Step Two:
Take the claw part of the can opener and hook it onto the sharp inner ring and pull out. This should pull out with little effort. If it is stuck just go around again with the can opener and try removing again.
Step 3: The End!
This is what you will end up with! :)
Be the First to Share
    • Plywood Contest
      Plywood Contest
    • Cheese Challenge
      Cheese Challenge
    • Microcontroller Contest
    2 Comments
    bettina-sisr
    bettina-sisr
    7 years ago on Introduction
    I didn't know about 'the claw', not sure if my opener has one. Also are you saying to use the opener twice? Once to open the can and again to take off the sharp rim? Where do you put the sharp edge on the opener the 2nd time? Thanks!
