Introduction: Remove the Vocals From a Song
If you need to remove the vocals or lyrics from a song in order to fix it or censor it, you've come to the right place. I'll tell you how to do just that, and I hope you like this tutorial!
The program I will be using, Audacity, can be downloaded here: http://audacity.sourceforge.net/
NOTE: This does not always work for all songs, but it does for most of them.
Video:
Step 1: Open Audacity
If you haven't downloaded it already, download it. It is free. If you have, then open it up to a new project.
Step 2: Drag in the Song
Drag in the song from your desktop, or any folder. You can also drag in the song straight from iTunes.
Step 3: Split the Stereo Track
Go to the upper left of the sound track and click on the drop down arrow next to the name of the song. Click on "Split Stereo Track".
Step 4: Select the Bottom Track
To do this, double click on the blue part of the lower track. It should turn a darker shade of gray than the other track.
Step 5: Invert the Bottom Track
Go to the Effects tab and click on "Invert". This flips around the lower track.
Step 6: Set Both Tracks to Mono
Next go back to the drop down arrow next to the name of the song, and click on "Mono". Do this for both tracks. This sets it so that each audio signal is routed through a single channel.
Step 7: Export It
Lastly, click the play button to make sure that the vocals are gone. If so, go up to the File tab and click "Export". Once you do this, a box or two may pop up asking you to choose what name you want to export it as. Type in the name you want and press either Ok or Export. You should be good! If your vocals could not be removed, I apologize, but some songs have vocals that can't be removed completely. I wish you the best of luck though!
DIY Soundhack Contest
Epilog Challenge V
5 People Made This Project!
- VenPal717 made it!
- SANNIKITA made it!
- Narto Sunarno made it!
- MinefunnyP made it!
See 1 More
105 Comments
9 years ago on Step 7
Awesomeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.
Thanks!
2 years ago on Step 6
No mono button what's going onnnnnnn
Reply 1 year ago
that is right
Question 2 years ago on Step 6
there is no option here like mono &
Step 6: Set Both Tracks to Mono not possiable
Answer 2 years ago
I thought it was common sense, but mono means no stereo input meaning that you would have to adjust the L & R knobs and pan to the "center". I hoped that helped :)
2 years ago on Step 1
How to turn off mute audio
Question 2 years ago on Introduction
Hey there I’m using your methods but when I get to the step where I need to put both tracks to mono it doesn’t let me. Is there any other way I can remove the vocals or find a way to set both tracks to mono?
The Mono is not showing on the drop down list
3 years ago
May i download now?
Question 3 years ago on Introduction
Can this be used to remove an instrument from a track as well?
3 years ago
If you're not getting the "Mono" option, click on "Split Stereo to Mono" instead of "Split Setreo Track".
mono dosen't appear for me....
Question 3 years ago on Step 5
My "Invert" effect is enable. What should I do?
Question 3 years ago on Step 7
I followed all the steps, but I can still hear the vocals playing in the background at a lower volume. But I can still hear them. I want to remove it completely. Please please help me!
Question 3 years ago on Step 6
There is no mono option in the drop-down arrow. What should I do?
3 years ago
does not work on Guns'n Roses rocket queen
Question 4 years ago
Why are you guys answering about the "pan" to the left or right? Every question here is asking about the damn mono and you're answering about the pan option... What's going on with you guys? The L-R is the pan which makes the sound of the song come out on either the left side or the right side of you earphones/headphones/speakers...
I'm also in need to know about the mono option, why isn't it there in the lastest version? But I know you still need to change the pan back to zero.
Answer 4 years ago
OKAY, I'm fine now, I was just searching for more help in google, but i found this one that helped me straight away.
So, the solution was: (Start from adding the song)
1. After adding the song, just click the arrow of your song track, select "Split Track To Mono" then, select your bottom track and 'Effects -> Invert' and you're done with removing the beats or whatever.
vvv Thanks to the solution! (the one posted by steve or someone but just scroll down)
https://forum.audacityteam.org/viewtopic.php?f=48&...
Have a great day guys!
4 years ago
I followed all the above instruction but failed to remove vocal. Can you please help me?
