Introduction: Repair Thomas Heritage Chiropractic Drop Table
How to repair a Thomas Heritage Drop Table Drop Mechanism.
When the drop table no longer pops up and stays up, you need to replace the bearings. There are 3 bearings per section of the table (thoracic section, lumbopelvic section). There are two types of bearings: 2 guide bearings and 1 stainless bearing (with bbs). They are available from Michael's Chiropractic in Davenport, Iowa. Give them a call. Or someone said they are the same as the ones you have for roller skates.
I suggest you take photos of everything you do along the way so that it's easier to put it back together.
Total time to repair both the thoracic and lumbopelvic section was 1 hour.
Step 1:
Instructions on How to repair a Thomas Heritage Drop Table Drop Mechanism.
1. Remove the silver L-shaped bracket. (Screw driver and socket wrench)
2. Remove the brown L-shaped bracket from the underside of the table top. (Screw driver)
3. Remove the tension knob which is a very long screw.
4. Remove the guide bearings as needed. (crescent wrench)
5. Remove the brown drop mechanism that looks like a piston. (crescent wrench)
6. Pull out the "piston" thing that holds the stainless steel bearing. (pliers)
7. Replace the stainless steel bearing. (crescent wrench)
8. Reattach the brown drop mechanism. (crescent wrench)
9. Attach the new guide bearings. (crescent wrench)
10. Reassemble in reverse.
11. Test to determine if the drop mechanism is working correctly.
