Introduction: SPEEDsSTACK Stopwatch
In this instructable i will show how to make a touch sensitive stopwatch like the SpeedStack's stopwatch.
Step 1: Supplies:
* Arduino pro mini
* Adafruit OLED screen (128*68 i2c)
* Copper tape
* 2 Leds
* 2 10 Kohm resistors
* 3 220 ohm resistors
* Wire
****** NOTICE: The touch sensitive are actually made of copper tape and resistor using the CapSense lib.
Also, usually i use the Arduino UNO at the planing and designing state and when done change to Arduino Pro Mini
Step 2: Used Libraries :
I used several of them :
1. For the capacitive touch i used the CapSense library.
2. For the OLED display i used several of them that requier each other :
SPI.h - The library is used to communicate over SPI protocol.
WIRE.h - Used to communicate over I2C protocol
Adafruit-GFX-Library - Used to work with the OLED display.
Adafruit_SSD1306 - Used for the monochrome OLED based on SSD1306 drivers.
Step 3: CODE :
#include
#include #include #include #include
#define OLED_RESET 4 Adafruit_SSD1306 display(OLED_RESET);
#define Red 7 #define Green 8 #define ResetB 6 #define Sensitive 20 #define delayRun 2000 #define blinkDelay 75
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endifCapacitiveSensor cs_4_2 = CapacitiveSensor(5, 4); // 10M resistor between pins 4 & 2, pin 2 is sensor pin, add a wire and or foil if desired CapacitiveSensor cs_4_6 = CapacitiveSensor(3, 2); // 10M resistor between pins 4 & 6, pin 6 is sensor pin, add a wire and or foil
boolean hold = false, runT = false; long holdTime, stopWatch; long total1 ; long total2 ; long calculator, blinkCount = 0, over; int Hours, Minuts, Seconds, Tseconds;
void setup()
cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF); // turn off autocalibrate on channel 1 - just as an example
Serial.begin(9600);
pinMode (Red, OUTPUT);
pinMode (Green, OUTPUT);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(0,0);
}void loop()
// *** Read touch-sensors
long total1 = cs_4_2.capacitiveSensor(30);
long total2 = cs_4_6.capacitiveSensor(30);
//display.clearDisplay();
display.setCursor (0,0);
display.print ("SPEEDsTACK");
display.display();
// *** A touch bouth sides
if (total1 >= Sensitive && total2 >= Sensitive && hold == false) {
digitalWrite (Green, HIGH);
digitalWrite (Red, HIGH);
holdTime = millis() + delayRun;
// Serial.print ("holdTime = ");
display.setCursor(0,30);
display.print ("--READY--");
display.display();
hold = true;
} // *** Go green light after delay
if (millis() >= holdTime && hold == true) {
digitalWrite (Red, LOW);
display.setCursor(10,30);
display.print ("** GO **");
display.display();
while (hold == true) {
//Serial.println ("hold loop");
// *** Waiting for bouth untouched
while (total1 >= Sensitive && total2 >= Sensitive && hold == true) {
delay (10);
// *** Wating for re-touch
while (total1 <= Sensitive || total2 <= Sensitive && hold == true) {
if (runT == false) {
Serial.println (" *** Zeroing ***");
stopWatch = millis() + 10;
runT = true;
blinkCount = 0;
calculator = millis() - stopWatch;
//display.setCursor(0,0);
//display.print (calculator);
//display.display();
Hours = int(calculator / 3600000);
over = calculator % 3600000;
Minuts = int(over / 60000);
over = over % 60000;
Seconds = int(over / 1000);
Tseconds = over % 1000;
display.print (Hours);
display.print (":");
display.print (Minuts);
display.print (Seconds);
display.println (Tseconds);
display.display();
if (calculator >= blinkCount + blinkDelay) {
Serial.println ("***BlinK***");
digitalWrite (Green, !digitalRead (Green));
blinkCount = calculator;
if (runT == true) {
stopWatch = millis() - stopWatch;
Hours = int(stopWatch / 3600000);
over = stopWatch % 3600000;
display.display();
hold = false;
runT = false;
digitalWrite (Green, LOW);
blinkCount = millis();
while (!digitalRead (ResetB)) {
if (millis() >= blinkCount + blinkDelay) {
// Serial.println ("***BlinK***");
digitalWrite (Red, !digitalRead (Green));
} // *** A touch only one side
if (total1 >= Sensitive && total2 <= Sensitive || total1 <= Sensitive && total2 >= Sensitive) {
hold = false;
display.setCursor(32,30);
display.print ("<<<>>>");
display.display();
Serial.print (total1);
Serial.print ("\t");
Serial.println (total1);
Serial.println ("ONE Touch");
} //*** No touch at all
if (total1 <= Sensitive && total2 <= Sensitive) {
hold = false;
Serial.println ("NO Touch");
Serial.print(total1); // print sensor output 1
Serial.print("\t");
Serial.println(total2); // print sensor output 2
delay(10); // arbitrary delay to limit data to serial port
}Step 4: Placing and Painting
After all the electronics was set I placed all the componets and wires using 3M dubble sided tape and a regular electric tape.
Then I designed and printed a sicker, and sicked it to the stopwatch.
The area were the sticker does not cover, i painted using PlastiDip paint.
