Introduction: STM32 Black Pill Board | Blinking On-board LED
This blog post is a guide to start your STM32 Black Pill and control the on-board LED using a program on STM32CubeIDE.
Software:
  • STM32CubeIDE
  • STM32CubeProgrammer
Hardware:
  • Desktop or a laptop
  • USB-C cable
  • STM32 Black Pill
Step 1: Create a Project File on STM32CubeIDE
Create a project file.
  • Type the project name.
  • Choose your preferred programming language, binary type and project type.
  • Choose "Add necessary library files" for less errors and problems.
Step 2: Pinout & Clock Configurations
Follow the steps shown in the attachments. And configure the pin-out and clock as per your board and requirement.
Save your file.
Step 3: Code
  • Save your file, this will generate files.
  • Go to Core < Src < main.c.
  • Go to int main() which is around line 95.
  • Change the code inside while(1).
[while(1) is an infinite loop which is used in embedded electronics.]
    HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, 1);
HAL_Delay(500);
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, 0);
HAL_Delay(500);
  • Finally, debug the code.
Step 4: Open the Project File in File Explorer
  • Copy the path of .elf file.
Step 5: Setup STM32CubeProgrammer
  • We will bootload STM using USB, this tutorial does not use ST-Link.
  • Next, press on "Open file" and select the .elf file from the project folder.
  • Press on "Download".
  • Go to "Erasing and Programming" from the menu in the left.
  • Go to file path and select the .elf file and press "Start automatic mode".
Step 6: Result
Once compiled, disconnect and reconnect the STM board using USB-C cable.
Voila, your STM32 Board's onboard LED should now start blinking.
Thank you!
