Introduction: Salt Water Metal Etching
I am a sword and knife enthusiast who always found the little etching on the side of my weapons super cool. I searched the web for several ways to make my own etchings on my weapons. To my dismay, there were few methods that did not contain harsh, dangerous chemicals that I didn't have at that time.Then a little spark of light appeared to me in the form of salt water etching! This method contains a few household items that are readily available and cheap.
WARNING: This method produced a harmful gas that should not be breathed in. Please use in a well ventilated area.
Step 1: Items Needed
All the items that are needed can be found around the house or for cheap elsewhere.
Items:
Salt
Water
Blade (steel works best, stainless or carbon)
9v Battery
A pair of alligator clips
Alcohol or Windex
Q-Tips
Electric Tape
Nail Polish (optional)
Pen/Pencil/Pin
Some Artistic Ability
Light/Workspace
Step 2: Cleaning/Mixing Salt and Water
Take some alcohol or Windex and clean the blade thoroughly. This helps the process go smoother. Also make sure the alligator clips, battery, and all other necessary components are clean and functioning properly.
At this time also mix the salt and water. I find that using one tablespoon of salt per cup of water works pretty well. Warm water makes the salt dissolve quicker. Remember, you don't need much salt water.
Step 3: Plan and Execute
This is were you need a little artistic ability.
If you plan on making pretty simple geometric shapes you can use only electric tape. If you plan on doing any other shape with curvy lines and whatnot you can use nail polish (I've also heard that Sharpie works too, but I have not tried that).
If you feel you cannot do that you can go to any local print shop and ask for custom vinyl stencils. If they cannot do them, they can probably tell you who can.
ELECTRIC TAPE:
Place a square around the area you plan on etching. Next get a razor or exacto knife and cut the other shapes needed out of electrical tape. This takes patience and concentration. Lay them down accordingly onto the blade. Make sure you press the tape down really well because if anything gets past it, it will mark areas you don't want to.
NAIL POLISH:
Paint down nail polish were you plan on etching. Make a electric tape border once it is dry. Take your pencil, pin, or any other small device and carve away the polish where you want to etch. This takes time because you need to make sure all the little pieces of polish are out of the grooves you create.
Step 4: Almost There
Now you can set up your little etching device.
Take one alligator clip and attach one end to the positive part on the battery (my red clip). Take the other end and put it on an empty part of the blade. Be careful where you place it on the blade, mine slipped off a few times.
Take the other alligator clip and attach one end to the negative part on the battery (my green clip). Dip a Q-tip in the salt water. I find that you need to get it wet enough that it isn't 'just moist' but it isn't dripping wet. Attach the remaining end of the alligator clip to the Q- tip head. You don't need it on the very end, but it needs to be touching the water.
Step 5: Etching
Now we can etch!
Place the Q-tip head onto the blade where you want to etch. Move slowly while passing over your entire design. I like to rock it back and forth while I move. You will notice a little puff of white smoke and a pungent odor as you etch, do not breath this in! Use in a well ventilated area. This is also a sign that it is working. Look at your Q-tip. It should be changing colors, from blue-green to a brown. This is the metal that you are removing. When the Q-tip gets really dirty looking take the clip off, dip the other end in water, add clip, and continue. The more passes you make with new Q-tips, the darker and deeper the etch will be. I use about 3-4 Q-tips.
When you feel like it is ready, remove the clips and walk over to a sink. Wash all the water off (while pointing the blade tip down) and remove the tape then dry. If your etch is still there good! You did it! Congrats! Hope you liked the instructable!
11 People Made This Project!
- Doc Barrington made it!
- Skerr1988 made it!
- Fractured100 made it!
- EetuL2 made it!
- juan antonioa7 made it!
- Nkroeker made it!
- luftbuefel made it!
- unhalt made it!
See 2 More
24 Comments
5 days ago
Hello! I can't find it in English - does anyone use water soluble paper to transfer laser printed designs? In Russia, many people do this... :)
8 years ago on Introduction
What do you think about dipping metal in electrified salt water. I'm going to see if I can make it work, but have you thought about it before?
Reply 2 years ago
This has been done millions of times. Yes, it also works, but the water has a much greater chance of getting under your decal than the moisture from an absorbent q-tip does. Using a saltwater bath will work fast, yes, but it will work messy and you will get no clean lines in the end.
How about using a paint brush instead of the Q-tip? Perhaps you could swish the brush around in the saltwater to clean it off, at the same time loading it up.
Reply 2 years ago
A little pain brush won't hold the same volume of salt water as a similarly sized q-tip will, and you need the salt water to make this work. Not enough salt water, and your q-tip will quickly wear out. You are doing yourself a favor (most times) by using a q-tip and getting it pretty wet. Paintbrush won't hack it! Not really. Plus, you'd have to discard it entirely once you were done with this project.
6 years ago
I want to do this with a large outline and fill. Someone mentioned using a cotton ball instead of a qtip. Has anyone done this or would recommend it? Also could I use a higher volt battery if I'm doing a larger piece? Please let me know :)
Reply 2 years ago
The voltage of the battery has no relationship to the size of the metal piece you are etching. A battery with higher voltage and delivered at greater ampereage will etch more quickly, possibly with more ragged edges, and will generate sludge and smoke more quickly and in larger amounts than a smaller battery. You can etch plate mail armor with a button battery, but because those are usually <3V it will take a long time. It would take the same amount of time to etch a steel napkin ring with the same design.
4 years ago
Nice instructable! But just a side note, the gas that is created is Hydrogen, which is harmless, yet flammable. In fact we breathe it all the time.
Question 4 years ago on Step 5
Hey there, how long would you say it should take to make that letter? And how long do you remain in onw general area before moving on? Thanks!
6 years ago
works well. not one that's super smooth but I like the look of it. made mine with a dispensary sticker.
6 years ago
Will this work on pewter?
6 years ago
i tried it it worked but i also had an idea i tried it useing my arc welder and it worked even faster and better plus instead of qtips i used cotton balls coverd a bigger area
7 years ago on Introduction
Does this work with stainless steel? Has anyone actually etched stainless steel this way and can verify it works?
I will have to try this for free-hand etching sometime. I've never seen a method without immersion before. Thanks!
7 years ago on Step 4
Would this work on aluminum?
This process will work on aluminum but it is much slower and less effective.
8 years ago on Step 5
great
I usually grab a bottle of heavy tile cleaner (phosphoric acid) from my old mans work (tile shop) and thatll do the trick without any lectricity or anything, but it doesnt seem to work on Cr5Mo15V steel so ill give this ago
Great instructable! I tried it on a machete and it worked great, thanks for the advice! It took me 2 9-volt batteries to do as much as I did though, it really burns them up.
9 years ago on Introduction
Will this method work on aluminum?
