Save Your Back: U-shaped Cedar Raised Garden
26,794
201
17
Introduction: Save Your Back: U-shaped Cedar Raised Garden
I just made a raised vegetable garden for my wife. I used red cedar for the parts that touch the soil to prevent contaminating it with treated wood, which I used only for the bottom. It took me about 40 hours to design and build this; the supplies cost me about 700 USD. I used common hand tools and an electric miter saw. I showed the results to a few friends who requested that I share plans and instructions, so here.
This is my first instructable and English is a second language, so my sincere apologies for any mistakes I made and please feel free to let me know how to improve on all this. Thanks!
Marc
Plywood 4’ X 8’ treated wood : 2
4X4 8’ treated wood : 3
2X4 8’ treated wood : 13
2X4 8’ cedar : 9
Cedar deck boards, sold as 2X6 (really 1 X 5½”) 16’ (can be cut into 16 8’ for transport) : 8
Galvanized wood screws 3” X 8 : 300
Galvanized wood screws 1½ X 8 : 300
Galvanized assembly plates 2 X 6 (screwed or hammered) : 16
Spruce strapping 1X2 (really ½ X 1½”) 8’ : 8
Galvanized welded ¼ mesh 36” X 25’
Geotextile 40” 20’
Optional : 1X styrofoam 2’X8’X1”, plastic film to wrap the cedar pieces exposed to earth
Optional : Ground layout : 50’ geotextile, 3 80L bags of colored cedar mulch, plastic border
Step 1: Site Preparation
  1. Cleanup a 11X11’ area in your yard for a 18” clearance around the raised garden
  2. If so desired, cover cleared ground with geotextile and cedar mulch, surround with plastic border.
Step 2: Base
Cut sixteen 4X4 trapeze-shaped 45° braces with 9” long side
Cut eight 4X4 legs of 16” length
Assemble the eight legs with braces on two adjacent sides; use lots of screws on this.
Cut 2X4 treated wood in the following dimensions; the 45° cuts are made on the 3½” side
  • Three pieces of trapeze-shaped 45° with 94” long side
  • Two pieces of trapezes-shaped 45° with 34” long side
  • One piece of trapeze-shaped 45° with 31” long side
  • Two pieces of parallelogram-shaped 45°, both sides same length: 60”
Assemble and screw the base 2X4's and legs
Step 3: Frame
Cut pieces of 2X4 treated wood in the following dimensions:
  • 92” : 2 pieces
  • 89” : 2 pieces
  • 59” : 2 pieces
  • 30” : 6 pieces
Cut twenty-four 6” pieces of 2X4 cedar
Assemble the bottom part of the frame as shown in the figure
Cut both plywood pieces using the dimensions shown in the second figure; cut-out openings (dotted lines) for the vertical 6” pieces.
Screw the floor to the bottom frame.
Cut pieces of 2X4 cedar in the same dimensions as for the bottom part of the frame:
  • 92” : 2 pieces
  • 89” : 2 pieces
  • 59” : 2 pieces
  • 30” : 6 pieces
Assemble the top frame (cedar) and join it with the bottom frame.
Turn the frame upside-down; put the upside-down base on top and assemble, then flip the assembly back up. NB : I had to screw a beam between the legs on each side to prevent them from bending/ripping out during the flip.
Step 4: Walls
Cut 1x5½ cedar boards to the following dimensions:
  • Three boards at 94” (rear)
  • Six boards at 92” (exterior sides)
  • Six boards at 35” (front left and right)
  • Six boards at 58” (interior sides of center alley)
  • Three boards at 26” (end of center alley)
Screw boards to frame.
Step 5: Weather-proofing (optional)
Insert 6”-high pieces of 1” styrofoam between the bottom and top framing.
Cover earth-exposed cedar with plastic film to slow-down rot.
Step 6: Floor
Drill ¾” holes every 8 inches or so along whole plywood floor for drainage.
Screw the 1X2 strapping strips every 8” or so.
Screw or staple the mesh to the strapping.
Cover with geotextile and staple in place.
Step 7: Optional 'gunwale'
This part is optional. I think it looks better with it, plus it keeps the earth in when the wind and rain pounce.
Rip three 1X5½”X8’ cedar boards in half along their length.
Round-out the cuts using a sander or router.
Measure the length at of each top wall board in the center; make the 45° cuts so the length along the center of the gunwale matches the wall board's.
Flatten the rounded top wall board using a sander or plane to ensure a solid gunwale assembly. Screw gunwale pieces centered on walls.
Step 8: Finish
Fill with earth, plants... I plan to add a drip irrigation system with timer (that's what the piece of black ABS pipe sticking out on the left side is for), but otherwise I'm pleased with the results and so is Nancy!
Be the First to Share
    • Puzzles Challenge
      Puzzles Challenge
    • Rice & Grains Challenge
    • CNC and 3D Printing Contest
    17 Comments
    Schimmy
    Schimmy
    Question 2 years ago on Step 6
    What is the purpose of the styrofoam?
    mvincent99
    mvincent99
    Answer 2 years ago
    At the time I built it, I was not sure what my wife would put in it, when we would seed, etc. We have freezing nights from October to May. I have done similar beds in the past where perennials were killed by frost, so the styrofoam here was just a precaution.
    lordbotabis
    lordbotabis
    2 years ago
    very inspirational build good job. Question? I am a little confused on this being soil containment free due to the treated plywood you have used for the bottom of the planter where the soil sits on. My question is, does your design have the treated plywood in contact with the bottom according to your pictures? Or am I not understanding correctly?
    thanks for the response as I am ordering lumber as we speak
    mvincent99
    mvincent99
    Reply 2 years ago
    Hi lordbotabis,
    The bottom is treated plywood, with lots of 1" holes for drainage. On top of that, I put some slats/strapping as spacers, a quarter-inch wire mesh and a thick geotextile, so the earth never touches the treated wood as there is an air gap in between. You can see the strapping and mesh on the first photo of step 6, just before I added the last piece of geotextile in the middle. Hope this clarifies things. Good luck with your build!
    OutofPatience
    OutofPatience
    3 years ago
    This is a lovely build...and your instructions and illustrations seem admirably clear...thank you! I'd love to have a couple of similar units in my yard instead of what we currently have! But ours were built with what we had on hand at the time, so maybe eventually we can upgrade!
    mvincent99
    mvincent99
    Reply 3 years ago
    Thanks! I also always try to reuse the material I have.
    radar76
    radar76
    Question 3 years ago
    can't read the dimensions of the raised garden bed in step 3.
    mvincent99
    mvincent99
    Answer 3 years ago
    Sorry about that. I guess you have to zoom the image in order to read the dimensions. The cut lengths are also listed below the picture. The leftmost and rightmost pieces are 92" while the horizontal (rear and middle) pieces are 89". All the short pieces are 30".
    M.J2
    M.J2
    3 years ago
    Nicely done!
    What a beautiful and functional build, quite the inspiration!
    BlackSheep1
    BlackSheep1
    3 years ago
    Bonus: that'll be easy to enclose with a cold-weather frame come winter, and keep right on growing vegetables and fruits. What a gorgeous planter!
    mvincent99
    mvincent99
    Reply 3 years ago
    I will definitely build a cover for winter; I plan to make it into a steep roof because of the heavy snow up we get up here. But I like your idea; I will make the panels removable so I can put clear plastic sheets on the structure and start gardening earlier.
    Barry6470
    Barry6470
    3 years ago
    Excellent build, it looks great so well done.
    Barry (ENG)
    mvincent99
    mvincent99
    Reply 3 years ago
    Thank you!
    Penolopy Bulnick
    Penolopy Bulnick
    3 years ago
    I love it! Such a nice looking planter :)
    mvincent99
    mvincent99
    Reply 3 years ago
    Thank you Penelopy!
    audreyobscura
    audreyobscura
    3 years ago
    I've been wanting to make something like this for my parents! Thanks for your insipiring project!
    mvincent99
    mvincent99
    Reply 3 years ago
    You're quite welcome and thank you for your comment!
