Introduction: Scrap Wood Balancing Rocks - Tumi Ishi
Most woodworking projects produce scraps and off cuts. Sometimes these can be quite small and only useful for the fire pit. But there is new hope for these forlorn little pieces of wood, turn them into endless hours of stacking balancing fun!
Tumi ishi is a Japanese game of stacking wood rocks. The goal is to make a tower as tall as possible, simple in concept but it becomes trickier with every block added.
Alternatively, wood rocks can be used to decorate your home in new and fun ways. The size of the rocks depends on the scrap pieces used.
Wood Rocks are fun and easy to make with minimal tools. I have made them with two different sets of tools but there are other ways to make these. The easiest method is a powered sander such as a disk sander or belt sander. An alternate method is with a vice and wood plane. A hand saw can be used to help create the initial shapes and sand paper is also helpful when the vice is not able to hold the wood well. No matter what way is used to make the rocks, personal protective equipment is a must. The only other thing needed is scraps of wood such as off cuts, scraps, checked wood or other bizarre pieces; the rocks are not picky.
Possible Tools-
Power Sander
Vise
Wood Plane
Hand Saw
Files
Sand Paper
Stain- If desired
Finish- I used danish oil
Required-
Wood- Scraps are great
Step 1: The Birth of a Rock
Now for the fun part, making rocks! The process I describe here will work with what ever method you have available. The first step is to see if the chunk of wood has any key features (i.e. weird angles, bevels, broken off piece etc). If it does, that can be the ground work for the shape of the rock. If the piece of wood is a bit big or square a hand saw can be used to make a non square cut to save time on removing material. If you are using a hand plane, the saw can be used to start the shape of the end grain.
The next step is to start removing material. I find it easier to remove material from a side, then immediately remove from the opposite side rather than working around the rock in a circular pattern. The pictures show a piece being progressively shaped as described. A key feature I focused on as I shaped a rock is to avoid ever having two parallel sides. We are trying to simulate nature.
Finally, it is just a wood rock from scraps. There is no right or wrong answer. If you like how it looks great, if not keep working at it. Worst case the fire pit finally gets the scrap.
Step 2: Finish and Enjoy!
Now you have a selection of wood rocks. Add the finish of choice and enjoy!
Second Prize in the
Scraps Speed Challenge
4 People Made This Project!
- dvanderson made it!
- missnebulajones made it!
- taichichuanwijchen made it!
- dadswoodshop made it!
12 Comments
1 year ago
I love this idea so much, thank you for sharing and congrats on second place!
2 years ago
Congrats on Second Prize! These stacking rocks are so understated but decorative! I always love working and decorating with natural materials, so I appreciate the thought that went into this. Well-done! :)
2 years ago
I love these!
2 years ago
Awesome job! This is well done!
2 years ago
I've made some marvelous futuristic scrap wood cars that just fly! My students got involved and began making scrap wood space ships, boats, barges, etc. There's a lot that can be done with scrap wood besides burning it. Great photos and 'ible! Thanks.
2 years ago
This is great! And I'd think a sanding disc maker, say like 3M, would get behind promoting this! Or at least those makers of gum cleaner sticks for sanding discs/belts!
2 years ago
Amazing! Regret about lots of scrap wood thrown out.
2 years ago
Great idea! I am definitely going to do this! Thanks for sharing.
2 years ago
My children will love this project. They build with my wood scraps already. Thanks
2 years ago
I love this. Finally all that scrap wood has a purpose. Thank you for the cool idea!
2 years ago
The is quite brilliant. I might actually do this and use up some of my hardwood scraps - I knew I was saving them for something! :D
2 years ago
Simple but very effective...I'm tempted to give these a go :)
