Introduction: Secret Roll on Stash
This secret stash is super easy to make and you can put it just in front of someone and he/she will never notice.
You can use any roll on container, although the size you have will limit the size of the thing you want to hide.
NOTE: Please be carefull when you are opening the container, the ball can pop long distances and it can hurt you, also when opening be carefull not to destroy the head or the ball. The better the condition of those two, the better hided they will be.
All you will need is:
- A finished Deodorant. - A fork (or a small tool used as lever to take the ball out) - The thing you want to hide (Container size)
Step 1: First Step - the Opening
The first thing you have to do is, very carfully not to damage to much the head of the container, take the ball out of the little compartment the head has so the ball can roll.
Also be carefull not to injure yourself doing this. If you need help, ask for it... and tell them to keep the secret.
The ball can fly away or just pop out, keep the ball, we will need it for the last step.
Step 2: Step 2 - the Cleaning
Of course the container will have residues of the product you used, so just go to a water source and clean it. It's important you dry it or the things you put in will wet wet and long termed rotten.
Step 3: Step 3 - the Hidding
Hide the things you need to hide, is a good place to hide money (bills), notes, even a key.
Step 4: Step 4 - the Closure
When you have you secret thing hided out in your compartment just put the ball back in.
In case you want to put more things in just open it again using in the same place you open it the first time to perserve the head of the container so no one notice.
Step 5: Step 5 - the Camuflage
After you put the ball back in, just put the cap on again and place it in the normal place you will have it so it can merge with your stuff and your secret will never be revealed.
