Self Balancing Segway Style Scooter for Under 300.00
Intro: Self Balancing Segway Style Scooter for Under 300.00
I've always wanted a Segway from the first day I saw one, but with the over 6000.00 price tag I couldn't afford one. Thankfully the parts required have come down in price dramatically. I managed to build one for under 300.00.
here is a list of the most important parts.
1x2" square steel on eBay but mine was scrap we got for free.
Sabertooth 2X25 motor controller from http://www.dimensionengineering.com/products/sabertooth2x25
electric mobility scooter motors ours are from the Jazzy electric chair the sell for 100-150.00 on eBay
5DOF IMU we got from eBay for 25.00 http://www.ebay.com/itm/181004141876?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Sealed lead acid batteries 12v from eBay or from hardware store
Thumb Joystick from spark-fun 3.95 https://www.sparkfun.com/products/9032
various switches and 10k potentiometers 5.00 from radio shack
code https://www.instructables.com/files/orig/FLC/KUAL/H6730DTD/FLCKUALH6730DTD.txt from sci chair instructable
schematic https://www.instructables.com/files/orig/F6O/M84D/GYO8A9EU/F6OM84DGYO8A9EU.pdf from sci chair instructable
79 Comments
easyvideo11 4 years ago
Then change the wiring diagram.
Can you tell me the recommended diagram of 9 degree
I am a handicap...
please help me,,,
5 Degrees of Freedom IDG500/ADXL335 is not available in online store
Scott_B 4 years ago
I've done my best to translate the wiring diagram from IMU originally specified to the Cryton SN-IMU5D-LC IMU. Best of luck building your scooter!
Cryton IMU Label Wire Color
5+ Blue
GND Black
Z-ACC Yellow
Y-RATEx4.7(INV) Purple
X-RATE White
Y-RATE Orange
titanren 6 years ago
I can't find the 5 DOF IMU . Can I use 6 DOF IMU instead it .
Thanks
said19 7 years ago
hey is there any way that i can get this code workign with mpu6050 because the analoge imu is not availabe in
김형진 7 years ago
hi
we are using 5DOF IMU but gyro ENC-03RC with accelometer ADXL335
but i think you are using gyro IDG500 with accelometer ADXL335...
is this why your code doesn't work with my IMU??
jimkan 9 years ago
Will your code work with MPU6050?
fozz18 7 years ago
fozz18 8 years ago
adirsingh96 8 years ago
hey,what is that tilt shifter and dead man switch
김형진 7 years ago
Hi, i have question.
what is tilt adjust shifter ??
Isn't it needs to lean forward to go forward and lean backward to break?
why do i need tilt adjst switch?
and what is dead man switch for ??
coolal 8 years ago
Can i control and move around using the handlebar?? how would i do this?
thank you
Jaitra 8 years ago
fozz18 8 years ago
Jaitra 8 years ago
VinceM10 8 years ago
Do you have to lean forward to drive? or is it controlled by the joystick
fozz18 8 years ago
kseskses 9 years ago
send video how to build it please?
how many fast it is?
yosuf.harb 9 years ago
how fast does it go??
Peter2011 9 years ago
could this be converted to a solo wheel, of course it will require to make the entire thing work by tilt sensor instead, or rather not a lot of retinkering, just need it to work with a single wheel, and a tiltsensor. instead of a analog stick.
fozz18 9 years ago
just dont hook up the steering pot and it will do the same thing.
found this for a good price
http://www.tinydeal.com/self-balancing-unicycle-with-210wh-samsung-lithium-battery-p-136027.html
