Introduction: Shorty Saw Horse
Step 1: Gather the Materials
I ended up just using scrap materials that I had collected from previous jobs. Here is a break down of what you need to make this pair of saw horses:
Materials:
Qty: Description:
(2) 2" x 6" x 59"
(4) 2" x 4" x 17"
(4) 1" x 4" x 16"
(32) #8 x 1.25" Drywall screws (16 for each horse)
Tools:
Hand saw or miter saw
Coping saw or Jig Saw
Drill/driver and bits
1/4" drill bit
Speed square
Pencil
Remember Safety First.
Step 2: Start the Cutting
Cut your pieces to length.
Step 3: Notch Out the Vertical Post
The easiest way to notch out the vertical supports is to drill out the corners with a 1/4" drill bit. And then use a coping saw or a jig saw to cut out the rest. The notch on the 2" x 4" is 2.5" in from each side and 4" down. This will make the notch a little bit big, so you will have to cut within the lines.
Step 4: Put It All Together
Start out by drilling some pilot holes in all the pieces, since you don't want anything to split. Then screw it all together. Making sure to have the leg 3.5" in from the end of the top beam.
Step 5: Design Modifications
If you don't feel like following the plan. No problem. If you don't have these scrap pieces laying around, you can make the whole thing out of 2x4 and 2x6, with a half lap joint (or not) on the 2x4's for the legs. If you shorten the top beam to 48", then you'll only need one 2"x6"x96". The only reason that I made it 59" was because that was what I had. I also wanted the horse to be wider then four feet for cutting a 4'x8' sheet of plywood. It just happened to work out.
If I had to make these again the only thing that I would change is that I would made the bottoms of the legs a bit wider, maybe adding an inch or two onto each side so that the bottom was 18" to 20" overall. I think that would add a bit more stability to the design. So that when you are pushing a sheet of plywood perpendicular to the sawhorse it wouldn't try to tip over. But I built it out of scrap stock which basically cost me nothing, so it's a small trade off.
4 Comments
12 years ago on Step 1
Hi - This looks like a great sawhorse and for a limited space workshop I love that it can easily be taken apart for better storage.
I think I'm missing something though. Is this material list for 1 sawhorse or for 2?
If I'm following the directions correctly for 2 sawhorses it looks like I would need
(2) 59" 2x6's
(4) 17" 2x4's (the legs right?)
(4) 16" 1x4's
This would calculate out to a shopping list of (1) 10' - 2x6, (1) 6' - 2x4, (1) 6' - 1x4, 24 screws.
Thanks.
Reply 12 years ago on Step 1
Nice catch on the typo's. The list should have been for a pair of saw horses, so yes it should have been:
(2) 59" 2x6's
(4) 17" 2x4's (the legs right? correct)
(4) 16" 1x4's (bottom leg stabilizers)
But it is 32 screws, since each end of the saw horse has 8 screws, which is 16 screws per horse.
I've made the necessary corrections within this instructable. Thanks.
13 years ago on Introduction
Hey aus...this is a great idea, a great project. Thanks for sharing! Cman.
Reply 13 years ago on Introduction
Thanks
