Introduction: Simple Workshop Cart (with Hidden Drawer)
For the last couple of months I've been busily reorganizing my workshop.
I've built all sorts of new stuff, including several cabinets, a large outfeed work table, and this new mobile workshop cart.
I wanted a simple but heavy-duty cart to hold my jointer and planer that allowed them to be moved around easily, and this is what I came up with. I was able to incorporate a slick little hidden drawer to boot!
This basic design could be adapted or modified for all kinds of uses, or even just simply used as a stand-alone portable work table.
A cart like this can be made pretty quickly (minus the drawer) from six 8-foot framing studs, some scrap material for the top, two casters, glue and screws, and some finishing supplies.
Step 1: In Use
Here's the completed cart, with my jointer and planer bolted in place. The lower shelf fits my scroll saw perfectly for storage.
This cart is rock solid, and exactly what I needed. I wish I would have built it years ago.
Alright, let's build this!
Step 2: Begin With the Top
Almost the entire cart was built upside down. That sounds a little funny but it works out nicely.
Begin by choosing the material you will use for the top, and cutting that out to the desired size.
You could use pretty much any kind of sheet material for the top of a cart like this. Plywood, MDF, real wooden boards . . . whatever you've got handy.
I had two small pieces of old solid-core doors left over from a previous project, and this is what I used. They were first trimmed as needed and then glued together with clamps to form one solid piece. The finished size was 38 1/2" by 25" (completed with trim in place as seen in the intro, the top is 40" by 26 1/2", and the cart is 30" tall.)
If I didn't have the door pieces I used, I would have doubled up two pieces of 3/4" plywood for the top.
Step 3: Cut Boards for Frame
I used standard framing studs to build a structure to support the top.
The frame consists of two main runners that extend beyond the top, which allowed for a handle to be built in. The handle was made from a section of an old wooden curtain rod.
See photo notes for various details. (The main photo in the next step has all of the dimensions I used.)
After trimming each board to the desired length, I ran the edges through the jointer and then table saw to trim the widths down to 3" and to square up all the edges. This is completely optional, but it creates cleaner looking joints when the doubled-up legs are made.
Step 4: Assemble Frame
All the boards were fastened together with wood glue and 2 1/2" screws, fastened into holes that were drilled and countersunk.
Step 5: Plug Holes
I used pieces of a 3/8" dowel to plug all of the countersunk holes.
I put a bit of glue on the ends, tapped them into the holes with a mallet, and then used a small flush-cut saw to trim them off.
I plugged 90 holes like this . . . it takes a little time, but I think it looks a lot better than having screw heads showing everywhere.
Step 6: Build Drawer
I built a simple drawer out of birch plywood and a piece of 1/4" MDF.
The frame was glued and tacked together with brads, and then fastened securely with 1 1/4" drywall screws fastened into countersunk holes. The bottom panel was simply glued and screwed in place.
Drawer guides were then installed on the drawer as well as the underside of the cart.
Step 7: Apply Finish
Prior to finishing I sanded the frame section of the cart with 220 grit sandpaper.
The frame of the cart was finished with boiled linseed oil. I brushed this on liberally, allowing plenty of time for it to soak in (especially on any end-grain areas), and then it was wiped down with a rag.
After about 24 hours, I applied three coats of spray-on lacquer, with a light sanding of 220 grit sandpaper between coats.
I used some scrap 3/4" pine as trim around the top board. This was fastened with glue and brads. After filling the holes with wood filler and sanding it smooth, the trim was coated with spray lacquer. The top was then painted white with a couple coats of brush-on primer.
The front face of the drawer was finished in the same manner as the frame, and was fastened to the drawer box with screws.
Step 8: Add a Shelf
I wasn't initially planning on adding a shelf, but decided it would be silly not to.
I added a brace across the middle with pocket screws, and two pieces of 1/4" MDF were cut as needed and screwed in place.
Step 9: Add Wheels and Non-slip Padding
Up until this point, I wasn't really sure what kind of wheels I was going to put on the cart.
I hadn't been to the store yet, so I had just planned on adapting the frame to whatever I bought.
I ended up buying two heavy duty polyurethane casters with 3" wheels.
The leg bottoms opposite the handle side of the cart had to have about 5" trimmed off, and an extra support piece needed to be added. These areas were touched up with finish so they matched the rest of the cart.
The wheels were fastened with 2" lag screws into drilled holes.
For the legs on the the handle side of the cart, I cut up an old computer mouse pad and glued pieces onto the bottoms of the legs with contact cement. They are super grippy and work great.
Step 10: Attach Tools!
My jointer and planer were then bolted in place to the top of the cart.
The bolts where the drawer was were a little too long and needed to be carefully ground off.
Step 11: That's It!
If you make a cart like this, please leave a comment and a photo to show it off.
I'd love to see how yours turns out!
21 Comments
7 years ago on Introduction
i neeed to build a bench in my shed. i have been trying to figure out what i want for drawers. this works for me! thanks for the idea...
Amazing. I didnt think about making a "wood" one of these! Great idea. I have enough scrap material around my house to almost build it without buying anything. Thank you!
Ein sehr gutes Projekt.Exzelent!!
Danke sehr!
Great 'structable. How about a tour of your shop?
Thanks!
A tour (so to speak) is forthcoming! ;)
I'm actually working on a couple more write-ups for things I built for my little shopspace, so keep an eye out for those.
Looks like I will be making two similar to this. One for the shop for my jointed and plainer and the other for the Kitchen. May end up with 3, 3rd one for the shop for drill press and scrole saw.
This cart is awesome. The half lap joinery and dowel plugs are great details and the drawer is an excellent use of otherwise wasted space.
Very detail... will use your idea to make a small kitchen Island... Thanks
What happens to the drawer when you lift it by the handle? I would think that if you had something heavier in it, gravity would dump the drawer. Have you seen this in action?
Ah, that's a great question.
I haven't had the drawer slide out while moving the cart. I used a full extension drawer guide that kind of snaps/locks into place when the drawer is fully pushed in.
I could see it potentially sliding out if it were fully loaded though, and I lifted the handle side of the cart more than a few inches off the floor. But that hasn't happened yet, as it only needs to be lifted an inch or so to roll it around.
Great observation; I was concerned about this as well until I found the right kind of drawer guides.
Thanks for the info!
Good craftsmanship! That table looks sturdy enough to support an elephant :-) I also like how you don't need chisels or router for the joints. I may have to steal it to make a simple router table.
7 years ago
Great idea. I've been thinking about doing something like this for my table saw.
7 years ago on Step 11
Love it!! That would make a great kitchen island as well!! Lots of ideas you're inspiring, Sam!
Thank you! Glad to share; I hope you're inspired to make something awesome.
niceeeee!
wow!
7 years ago
Great instructions. I plan on making one somewhat similar in the future. I love your design and may do this one. I'll definitely post pics when I do.
7 years ago on Step 8
The cart looks great and so do your pics and description. A good project all around!
