Introduction: Skinning and Filleting Catfish
So you caught a catfish: now what?
Step 1: Acquire a Catfish
Get yourself a catfish. There are several methods:
1. Catch your own. Juglines/trotlines are a good way to catch these bottom-feeders; just make sure you're not fishing in a polluted or heavy-metal laden waterway. Each US state has its own report on this subject.
2. Get one from friends who fish, but usually catch-and-release because they're scared of cleaning fish. Bass fishermen are great for this; my uncle only keeps his fish when I come to visit.
3. Buy a live one. If you have a good Chinatown, farmers' market, or live near a fish farm, this may be easy. It's sad that you're missing out on a nice day at the lake or the river, but at least you have a live fish. This ~2.5lb fish came from the Old Oakland Farmers' Market. I was in line behind a bunch of tiny asian grandmothers waiting to buy live catfish.
4. Buy a dead one. This is a total cop-out, but sometimes the only option. Fishmongers and grocery stores standardly sell fillets, but good ones may sell you whole fish for waaaaay cheaper. Sometimes they're even pre-skinned for you. Note that "basa" is catfish from Thailand forcibly renamed by the US government.
Step 2: Kill It
If you're starting out with a live catfish, congratulations! You know your food will be fresh. There are many ways to put the little guy out of his misery before you begin, but pithing is sure to do the trick. Whacking him on the head will certainly stun the fish and probably kill him, but is more about preventing the human from feeling squeamish.
To pith your catfish, position the pointy part of a big knife directly above its brain and spinal cord, then quickly push down into the brain cavity. This is about as quick and painless as euthanasia gets.
Step 3: Cut Around the Head
Cut just through the skin in a ring around the base of the head; this will be where you cut later to remove the head, but for now leave the head on to give you a better grip on the fish.
This creates an edge from which to start skinning.
Step 4: Remove Fins
Cut off the dorsal (back) and ventral (stomach) fins as they'll just get in your way as you manipulate the fish. You can leave the small ones on if you like, and the tail should stay on for ease in handling.
This farm-raised catfish has small soft fins; the average lake or channel cat has much larger, spinier fins capable of drawing blood and slicing through inflatable boats. (I've had to swim my trot line and mostly deflated boat back from the center of a pond before.) Make sure to remove these more dangerous fins as soon as possible to minimize danger in handling, and beware of the spines while landing your fish!
Step 5: Remove Skin
Small young farm-raised catfish like you see here have relatively thin, delicate skin. A bigger, older catfish has much thicker skin which can stand up to much more abuse in the skinning. These can be skinned using a pair of pliers; there are some nice instructions on the web for how to do this already. If your catfish is up to it, this method is MUCH faster.
My catfish's skin would not stand up to this sort of abuse, so I used the tried-and-true slow method of skin removal: fingers (or tweezers or pliers if you prefer) and a sharp knife. Just work your way from the head back and the top down. Keep your knife as close to the skin as possible; the sharper your knife the easier this will be. (Thanks, Tim!)
Hint: instead of trying to cut the skin off the catfish, think of it as cutting the fish off of its ski; you want to leave as much flesh as possible on the body of the fish.
Step 6: Remove Head and Guts
Locate the line you'd previously scored around the head for skinning, and cut through using a big knife. If the vertebrae are too thick to cut through with the knife, cut through everything else then bend the head back against the body until the vertebrae separate. You can then get your knife between the vertebrae, and cut through any remaining neural or connective tissues to remove the head.
Once the head is gone, cut a slit along the belly of the fish all the way back to the anal fin at the rear of the stomach cavity. Scoop out all of the suspicious bits and pile them with the head. Try not to puncture the guts, as this will make more of a stinky mess. Give the fish a rinse to make sure you got it all.
What to do with the head and guts? You can bury them under some deserving plants in your yard, though make sure to dig deep enough to keep racoons from unearthing them. If you live near an appropriate ocean, you can use the heads to bait your crab traps. Minus the bitter-tasting gills and washed free of residual guts, the heads can be used in making fish stock. Freeze the (cleaned and prepared) head in a dated bag until you're next ready to make stock.
Step 7: Understand Fish Morphology
Remember those great cartoon fish skeletons cartoon cats pull out of their mouths? That's a pretty accurate representation of the backbone you'll find inside your catfish. There are also small bones associated with the fins and ribs curving around the stomach.
Step 8: Filleting- Dorsal Cut
Hold your knife parallel to the fish over the dorsal (top) side of its body. Carefully slice in just to top side of the midline; the goal here is to cut as close as possible to the backbone as possible to remove the maximum amount of fish for your fillet. Continue slicing until you hit the vertebrae. Work from rostral (the front) to caudal (the tail).
Step 9: Filleting- Ventral Cut
Now that you've got the top half of your fillet done, lift it up and continue working your knife around the tail then back along the ventral (bottom/stomach) side. Hold up the tail section as you go, detaching the fillet from the vertebrae.
When you reach the ribs you'll need to trim carefully to avoid leaving ribs in your fillet. Think carefully: what are you planning to do with this piece of fish? If you're going to cut it into stir-fry nuggets it's OK to be faster and a bit messy in the rib area, while if you're going to use the fillets whole you should be more careful to keep them intact. This is most easily done by working from the backbone down, skimming along the ribs to remove as much flesh as possible.
Step 10: Filleting- Second Fillet
Turn the fish over and repeat the process on the other side. The same technique holds, though it can be more difficult to hold the fish and skim close to the bones with the other side of the fish already removed. Of course, this does make the spine more flexible; on the whole, a wash. Consider it a chance to perfect your technique and make a tidier fillet than you produced from the first side.
Step 11: Trim and Freeze Carcass
When you're done, there will probably be some tasty bits you missed, especially if you're a beginner, using a dull knife, or haven't filleted in a long time. I didn't do a good enough job cleaning off the flesh around the ribs, so went back and trimmed off the bits I'd missed.
Bag the carcass and put it in the freezer to use the next time I make fish stock. (Mmmmm, gumbo.) Label it with the month and year to avoid confusion.
Step 12: Clean Up Your Mess
Put your fillets or chunks into a bowl, make sure you've properly disposed of the head, guts, and skeleton, then scrub the cutting board and/or counter with soap and hot water. Paranoid freaks finish clean-up with bleach; determine your comfort level.
If you were smart enough to do this outside, bury the scraps and hose off the grass. Bonus: use the hose to spray any feral cats who have ventured too close during this operation.
Wash your hands thoroughly before proceeding to cook your dinner.
Step 13: Cook Your Catfish
Your catfish fillets are now ready for inclusion in your favorite recipes.
Catfish can stand up to extremely strong flavors, so are often used in very spicy creole or east asian dishes. It's good baked, steamed, deep-fried, pan-fried, stir-fried, in gumbo or soup, and in fish tacos. This is a picture of a stir-fry in progress; so far we've got onions, jalapenos, and sweet potatoes. Unfortunately my camera ran out of battery at that point, so it won't get its own instructable.
I'll put up linked projects as I make more catfish-based dinners, and would love to see what everyone else does with their catfish.
36 Comments
Tip 4 years ago on Step 2
Alternative way to kill is to cut its tail off and drain its blood, this makes the blood go out before filleting it. Make sure you stun the fish before doing so.
6 years ago
There are specific pliers made for this!
15 years ago on Introduction
I live in the south. The only way i was ever taught to skin catfish was to hang the fish up by the gills. make the first cut behind the head as you did. then take a pair of skinning pliers and grasp the dorsel fin and pull downward. this will remove the majority of the skin from the back. then go back to the sides. grasp the skin and pull downward. and repeat the process as nedded. i can clean any catfish fron 1lbs all the way 42lbs in the same manor and do it in less than 2 minutes each.
Reply 14 years ago on Introduction
EXACTLY, man alive I'd hate to see this guy clean a mess of cats... I caught 80 something last weekend, shoot, i'da been cleaning for a week at his rate.
Caught a 40 pound flat and had him dressed and filleted in about 5 minutes
course, Ive been doing it most of my life, and I do it for extra money, IE I sell fish at work, and typically cover the cost of my gear fuel etc and still put money in my pocket.
For anyone reading this, get a metal coat hanger, a pair of needle nose vise grips if you do not have access to skinning pliers, run the coat hanger though the gills out the mouth, and hang him about eye level on something very sturdy. Grab the tail and cut it off completely at the end of the spine. (this drains the blood and keeps the meat cleaner tasting) Take a new razor blade and cut just below the skull bone all the way around the head (RUB the head hard with your finger, you'll feel the bone) make a slit at the dorsal fin and or break and remove the fin totally, grab the skin at the cut and pull down very hard while firmly holding the meat up behind the skin to keep from losing it pull the skin all the way down as if you are removing a sock. rip open the stomach and gut it, remove stomach meat and save. break off head at skull base and fillet with a very thin and flexible fillet knife you can clean 20 to 30 fish an hour depending on skill and size smaller=easier
Reply 6 years ago
we just used a nail in a tree to hold the cat worked great.
Reply 13 years ago on Introduction
Next time you go out and have a friend with a camera handy could you put up an Instructable with your method of cleaning.
Most definitely I'm readying my lines and replacing all my hooks now, actually it's all done, I just have to build a new hook board because I'm now running 200 hooks and my old board was to small. Season is getting ready to start soon, as so as I get a mess, I'll post a video on youtube, I'm not to fancy on writing these things here
Videos are great addition to an instructable, but please make a proper instructable with still photos and written instructions. Thanks...
7 years ago on Step 4
why is the freshly caught catfish slimy and how do I get that off, is the catfish any good?
9 years ago on Introduction
Mouth... Watering... So... Bad...
9 years ago on Step 9
This guy made a mess of this , it can be done with 2 cuts straight down the side from the behind the head with a fillet knife before you get to the very end flip the fillet over with the knife in 1 sweeping cut and fillet the skin off for a 2 cut fillet , flip and do it again on the other side , with almost 0 mess and no worrying about guts or anything
10 years ago on Introduction
hey canida, i'm certainly referring to this 'ible next time i decide to keep one of the catfish
i'm a bass fisherwoman mostly (living right next to a river!) and the closest thing to a pest we have is catfish
ours are big, brown, slimy creatures that smell terrible!
i've found it hard to clean them due to their strong skin and bones and they are near impossible to keep hold of!
great instructable..well done
10 years ago on Step 13
mmmmmm, much tastier idea
hey wow, your catfish are much softer on the eyes then ours!
10 years ago on Step 2
I did this to a Bull catfish and it didnt work sucker was still alive i even tried three more times didnt work had to gut him anyway
10 years ago on Step 10
seems to me you have a very bloody fix there, i read were you leave the tail on to me that's a no no cut the sucker off let it bleed for 5 min's or so then fillet the meat off bone flip it over tilt knife a bit hold end of skin with skinning pliers and pull skin while pushing with other hand. that's all there is to it.
Tom Crawford.
11 years ago on Step 12
bloody cat-fish.
11 years ago on Step 4
Y did you use a boat that could be puctured and sunk with such little effort there are some boats that can be cut in half and still float
I have fished cats for a long time, when landing that bugger I always get finned by the top fin on the back. Sting like a bee. To get rid of the sting, rub the catfishes belly on the spot, some reason it helps. Just incase tidbit for newbies to the fishing world.
Reply 12 years ago on Introduction
The reson the sying goes away is cause the fin has a small amount of poisin in in. Nothing serious. Kinda like a bee sting. The slime from the belly seems to neutralize it.
