Introduction: Skorpion 2.0
About: My name is Daniel, I am a computer engineering student. Cooking and baking are my passion, sharing the knowledge that absolutely anyone can cook outstanding food is my goal. I am always willing to try somethi…
This a modern take on one of my favorite guns I've ever made. If you think it's just another generic firing pin gun, then don't leave just yet. This uses a very unique pin. Basically, all it is is a blue rod sticking out from between a bottom and top rail with gears to keep it on on either end. This can make a gun very compact and better looking, and more realistic.I seriously recommend building this gun. This idea will almost certainly work with bullpup guns too! Maybe you can get a few ideas, or maybe you can just have  lot of fun with it.
This gun is really fun to shoot!
Pros:
Decent range
Fun to shoot
small and packs a punch
Easy to load
Cons:
Gun is still not quite perfected; the pin may go under the trigger once in a while causing the gun not to work. Easily fixed with pulling the pin back a bit.
Handle isn't that comfortable
Get building! I'd love to hear some feedback on this gun.
Step 1: Outer Body
A panel that goes on the outside of the gun. Follow image notes.
Step 2: Handle
The handle of the skorpion.
Step 3: Inner Panel
An inner panel..
Step 4: Internals
The stuff that goes right in the middle.
Step 5: More Panels
More panels/internals.
The pictures in this step aren't very clear on what they want you to do, so I will go through them step by step.
Picture 1: Make this and clip it to the blue rods on the end so it lines up with everything else.
Picture 2: Make this and do the same with this as the previous piece but put it so it lines up with the other side of the magazine.
Picture 3: Do the same with this as the other pics.
Picture 4: Make this
Picture 5: Get a small piece of tape and a green rod
Picture 6: Stick it on the end of the tape
Picture 7: Put that piece from before in and make sure it lines up with the trigger
Picture 8: Put the green rod on the hole, and put the tape on the side.
Picture 9: Take the tape off of that specific part; you will need to have that hole accessible.
Next step!
Step 6: Other Outer Panel
Last panel that is needed! Just follow the pictures
Step 7: Almost All of the Rest..
Just finishing up the gun, loading and everything else is in the next step. Follow the pics, I was too lazy to put in image notes.
Step 8: Loading
Sorry, still too lazy to add image notes :P Have fun anyways, if you reaally need help, private message me.
