Introduction: Small Closet Solution - Hangers Without Can Tabs -
This is a lifehack to make another lifehack if you don´t have can tabs! Do you know all these `Life-hacks to organize your small closet´? I really like the idea of using can top tabs to be able to hang more clothes in the same space by connecting several hangers beneath each other, but I don´t have that many can tabs. So I thought of a different solution to hang several hangers into my closet without using can tabs.
Step 1: Here Is What You Need
Here is what you need for your no can tab hanger solution
- wire
- soldering iron and solder
- white paint
- paint brush
- scissor or tongs
Step 2: Wire
Cut a piece of wire (about 5 to 10 cm, depends on the thickness of the wire (If it´s thicker you need more wire)). Now cut the isolation that you have about half a centimeter without isolation on each end of the wire. (picture 1)
Now bend the wire into a circle.
Step 3: Soldering
Solder the ends of the wire together.
Step 4: Paint
In the last step you color the wire rings.
Step 5: There You Go
There you go - a no can tabs hanger solution for your closet. Now you can put several hangers under one another without using can tabs!
