Introduction: Smart Door Lock System
Disasters and mishaps arrive when you are least expecting them. In today’s day & age, proper home security is a must for everyone. Smart door locks function as the very first step in an effective home security setup. In today’s article, we will look into a step by step process on ‘How How To Make A Smart Door Lock’ using An IR Receiver & a Servo Motor.
You can make this circuit on Printed Circuit Board PCB to Order
Custom-built PCBs at amazingly low rates 2$ for 5 PCB’s Please visit: www.jlcpcb.com
Step 1: Hardware Required
- NE555 Timer IC
- Op-Amp IC LM358
- NPN Transistor 2n2222
- Servo Motor
- Relay Switch
- IR Emitter LED
- IR receiver TSOP1738
- LED
- Potentiometer
- Capacitors
- Resistors 10K, 68K, 33K, 4.7K, 1K, 560 Ohm, 220 Ohm
- Soldering Iron
- Diode 1N4007
- Soldering Wire with Flux
- Veroboard
- DC Battery with Clip
- Male Header pins
- Jumper Wires
Step 2:
Solder the pin 4 & 8 of the 555 timer IC on the vero board.
Step 3:
Solder a 33K Ohm resistance between pin 7 & pin 8 of the timer IC.
After that solder a 68K resistor between pin 6 & 7 of the timer IC.
Step 4:
Solder two 100 pF capacitors from pin 2 to pin 1 and pin 1 to pin 5 of the timer IC.
Step 5:
Solder the emitter of the 2n2222 transistor to pin 1 of the IC. After that, solder a 4.7K resistor between pin 8 & the collector of the transistor.
Step 6:
Solder a 5V relay on the Vero board & solder a 10K resistor between pin 6 & NO terminal of the relay.
Step 7:
Solder male headers for servo & LM358 Op-Amp on the veroboard
Step 8:
Solder the 10K pot & a 10K resistor between pin 4 & 3 of the Op-Amp.
Step 9:
Solder a 1N4007 Diode between relay coil pins. After that, solder it to the collector of the 2n2222 transistor with emitter soldered to pin 4 of the LM358 IC.
Step 10:
Connect a 220 Ohms resistor from pin 1 of the op-amp to +ve terminal of the LED & connect a 560 Ohm resistor from pin 1 of the op-amp to the base of the transistor. Connect the LED +ve to pin 1 & -ve to pin 4 of the op-amp.
Step 11:
Connect a 220 Ohm resistance on pin 4 of the op-amp.
Step 12:
Join the IR transmitter LED & receiver in series.
Step 13:
Connect the Vcc & GND for Both ICs. Connect servo to the headers & test the circuit.
