Snow Arch
37,819
102
53
Introduction: Snow Arch
After reading about Brunelleschi's Dome, my brother and I had an goal to build an arch out of snow. It doesn't follow his stone chain method, but it is a free standing arch.
Things you'll need,
- Snow of the right consistency. Not too dry, not too wet. Packable.
- Cool temperatures. This arch was built in warm temperature, which led to its short life of about an hour.
- Support braces. We used a series of sawhorses, boards, and snow.
- Ladder
- Block mold. We used kitty litter buckets. It should have flat sides and have a slight taper.
- Some sort of scrapping tool.
Snow Arch from Paul Maiorana on Vimeo.
Step 1: Foundation
Find a flat surface and clear an area about 3'x3' down to the ground. For our arch we had a distance of about 14' from center of support to center of support. As you can see from the picture, I used an ice scrapper to measure an equal distance from a point we wanted as center. Also notice we used a larger form for the first two rows of the arch.
Step 2: Stack and Fix
As you begin filling your forms and making your blocks, try and make them as compact as possible. Any weak areas of the block will eventually make your arch shift, trust me. Let the natural taper of your form begin to slowly form an arch. Do this by stacking every block with the small side of the taper towards the center of the arch. You will see it slowly bend towards the middle.
As the arch builds it's important to step back and adjust the pillars. It's snow, so it will shift and compact. Make sure you help the snow pillars get back to a true state, perfectly straight up and down from left to right. Obviously, keep the arch arching, but the front to back may need to be straightened.
Step 3: Build and Support
Now the fun starts... Keep forming blocks and keep stacking. Keep adjusting front to back and keep stepping back to make sure both sides are arching in with the same degree and curve. As the pillars grow in, they will need support. You want to keep this as simple but as strong as possible. We used sawhorses with a simple board for the first layer. We supplemented smaller supports by using blocks of snow that didn't make the cut for the arch. Make sure you support the natural arch of the snow, do not over support it by pushing the curve up.
Step 4: Keep Stacking
Keep stacking and adjusting from front to back. Make sure both pillars take the same shape and are working towards aligning at the top. As you keep staking, add another board for support. Then more snow supports then another board as you see if. This will vary depending on the size of your arch.
Also, you can see that we've added some front to back supports. Our blocks were very wet and heavy and compressed a great deal, which led to some serious front to back movement. We added some front and back buttresses to add support. We needed this to make this thing stand. You may need it too.
VERY IMPORTANT
Be careful of hoop stress. Hoop stress is the outward force the arch sends due to the vertical weight on the curve. The goal is the properly direct all this stress into the ground. Do this by keep a smooth curve from the bottom of the curve to the top. If you have vertical sides on the lower portions of the pillars you will have increased hoop stress. If you have too much stress the arch will kick out the sides and collapse. Keep this in mind as you build.
Step 5: Topping Off With a Keystone
Keep your arch growing until you have a space approximately the shape of a triangle on the top. This wedge piece is call the keystone. This locks in the arch and makes the entire arch lean against itself, thus eliminating the need for your entire support system. This piece needs to fit perfectly. After this piece is placed, it is your last chance to true up the arch. Make any serious adjustments now before the support system is removed.
Step 6: Remove the Supports
Once the arch is completed and you've trued it up and you've filled any cracks with additional snow, it's time to remove your supports. Start at the top, and remove the snow from under the keystone. Then move to either side and take a little more snow out. As you remove snow, see how your arch reacts. Does it sink, settle, and compress more? This might be because you supported it too much. Basically, dismantle your support system very slowly. This is where most arches fail, even stone ones.
Step 7: Enjoy Your Arch
Once you've taken the time to build the arch, make sure you take the time to enjoy it. After all it is snow and won't last forever.
Our arch lasted about an hour before it collapsed. It was way too warm for this one to last, but yours might be able to last for days!
Step 8: What Goes Up, Must Come Down
Watch how the arch changes shape over the one hour of it's life. We noticed where our weak spots were and how a curve that is not perfect is an arch in danger. Check out the final photos and video. The video is the last eight minutes of the arch's life. Each second is about one minute, until the crash. Be sure to watch the slow motion reverse crash. :)
Enjoy your arch making!
Be the First to Share
    • Fabric Challenge
      Fabric Challenge
    • Backyard Contest
      Backyard Contest
    • Eggs Challenge
      Eggs Challenge
    53 Comments
    canida
    canida
    13 years ago on Introduction
    Cool! Now all I need is snow...
    canida
    canida
    Reply 13 years ago on Introduction
    *makes sad face as it melts immediately* It was 70F here today. Not so good for snow.
    Arbitror
    Arbitror
    Reply 12 years ago on Introduction
    Heheh, I'm a Canadian, and I also know it snows in the US.
    By the way, I don't live in an igloo, there is only snow here for one of the seasons!
    andrew_29
    andrew_29
      i live in ottawa canada and there is snow just about 6 months a year and i make a half pipe and an iglu every year!
    Arbitror
    Arbitror
    I love where I live, because the seasons are pretty much balanced. There is basically 3 months of each season.
    awesume
    awesume
    Reply 11 years ago on Introduction
    I live in Texas. And no I don' live in the middle of no where I live in dallas 6th most populated ciy in the US. We get snow about every other winter. in summer this year the highest temperture was 115 degrees F.
    firefly68
    firefly68
    awesume, you gave me a good laugh! I lived in Dallas one winter and it snowed all of 1/2". It shut the whole city down! Coming from the northeast, I was in shock at the effect such a teeny little dusting could have on such a huge city. It's understandable, but it was surprising.
    gmjhowe
    gmjhowe
    And, may i ask, with all your wondrous items e.g. your laser cutter, why do you not have a snow machine? Laser cutter, but no snow machine... doesn't sound good enough to me!
    canida
    canida
    See comment above; it would melt as fast as we could make it! Unfortunately we have to drive to the Sierras to get cold snowy weather.
    Pie Ninja
    Pie Ninja
    I live in Australia, there are very few places here where it snows. :L
    Pie Ninja
    Pie Ninja
    Why thankyou, fellow Hitchhiker's Guide to the Galaxy fan.
    jcksparr0w
    jcksparr0w
    10 years ago on Step 8
    reminds me of the old game arch rival. am definitely going to try this winter!!
    ssully1210
    ssully1210
    Hey, how about for your next project you make a snow Stonehenge?  build it, let it freeze up and then on next warm day, snow on ground will melt off leaving what would look like stone from a distance.  Don't have big enough yard, or I would try it myself!
    finfan7
    finfan7
    I live in tucson, AZ in the middle of the sonoran desert.. If I didn't I would build lots of these. These are awesome.
