Solar Powered Raspberry Pi
335,583
616
27
Introduction: Solar Powered Raspberry Pi
About: Making Stuff since the 80's
What i'm going to show you today is how to run your raspberry pi off the sun using solar power & Battery.
Step 1: What You Need
Step 2: Connecting the Battery
First off we need to connect the wire to car power adapter then to the battery.
The battery is a 12V 1.3 ampHour battery The length of time the battery last very much depends on what you are doing with.
But here is quick calculation
If the raspberry pi uses 3 watts a hour then a 12v battery at 1.3 amp hours gives 15.6 watt hours
So 15.6 divide by 3 gives you 5.3 hours.
So the battery should last about 5 hours
If you want it to last long get a bigger batter or wire two up in parallel
Step 3: Connecting USB
Next we need to plug in the usb power adapter.
I know it possible to make a power adapter from a 12v Battery to USB connection however this way is easier and almost as cheap.
If you would like to make your own adapter search on instructables
Step 4: Connect the Solar Panel
Connect the solar panel to the battery and point it at the sun.
And now all thats left to do is power up the pi
Hurricane Lasers Contest
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Big and Small Contest
    27 Comments
    Compubyte
    Compubyte
    Question 1 year ago
    I know this is old, but, can someone explain how this is supposed to work??
    I do NOT get it? it's a 1.3 Ah a battery. a PI requires 2.5 amps to RUN properly ( and a pi 4 requires 3 amps). So how can you use a 1.3 amps on something requiring more output?
    cookiemunsta
    cookiemunsta
    Answer 5 months ago
    1.3 Ah isn't 1.3 amps on the 12v Battery, it's the storage density. Amp hours (Ah) is an equivalent of 1 Amp draw per hour. This 12v battery is 1.3Ah, which means you could pull 1A of electricity continously for 1.3 hrs @ 12v before the battery is dead
    A 12v 50Ah battery would mean you could pull 1A @ 12V for 50 hours for example, and if you had a device that pulled 2A @ 12v it would last half that because it's double the draw
    thenewworld1982
    thenewworld1982
    2 years ago
    I have this battery and panel laying around as well as a ups that don't have a battery in it could I make u.p.s solar also then use power adapter to step down voltage
    PhenomenonX1
    PhenomenonX1
    3 years ago
    This very useful my friend thank you
    kschildt
    kschildt
    3 years ago on Introduction
    Does the Pi use 3 watts at 12 volts or 5? Your power consumption appears incorrect. It would be better to use a 6 volt system in order to minimize the power loss in the voltage regulator. A step down from 12v to 5v is wasteful.
    RudiA4
    RudiA4
    Question 4 years ago
    I don't have a battery yet. How long does the Pi run off that battery during the night?
    AndreG68
    AndreG68
    6 years ago
    This is a very helpful post. I want to run a rpi off solar in a context where there is no other power source. I have read that the rpi or sd cards might be damaged if it suddenly powers off when the battery runs out. It would be best, therefore to include in the setup something that will initiate a clear shut down when the battery voltage dips below a certain point. I would like to use a cheap 3.3V arduino mini pro to do this job. Are there any instructables around that show how to set something like that up? are there any cheaper solutions that will do the same job?
    KandiK1
    KandiK1
    7 years ago
    Not bad, I just use a 7AH battery instead with a 5 watt and it runs continuously. Quick to charge when the sun comes up too. Might get a 12AH battery later for it. You don't wanna discharge them past a certain percentage too much.
    KandiK1
    KandiK1
    Reply 7 years ago
    5 watt solar panel i means.
    MaciejS14
    MaciejS14
    7 years ago
    Hello. I have a question to anyone who actually built above setup. What happens when the current from battery runs out and there is not enough sun to power the Pi? I imagine that it switches off but does it automatically switch on then the power is back?
    sparky3489
    sparky3489
    7 years ago
    You may want to look into a UPS instead. I have an advanced design for one, I just haven't actually built it yet. I can give you the plans if you like.
    sparky3489 at yahoo dot com
    BradysoBOT
    BradysoBOT
    7 years ago on Introduction
    this is a great project, but is there a way to make it switch to wall power once the battery runs dead? I use mine as a web server and I can't have it go down.
    JohnM374
    JohnM374
    Reply 7 years ago
    yes. it gets more complex though. you need a series of relays which can trigger when the battery voltage gets too low, and when the voltage gets back up to fully charged.
    JohnM374
    JohnM374
    Reply 7 years ago
    JamesS79
    JamesS79
    Checkout a charging circuit, which should get you on your way to a full blown UPS
    MadPierre
    MadPierre
    7 years ago
    Been out and got my bits. My plan in the future is to have a solar power cctv system
    Dodutils
    Dodutils
    Little question, why 12V Solar cell + Battery and not 6V ?
    AlbericoS
    AlbericoS
    8 years ago on Introduction
    hey there is was just wondering if you could run the rpi using this solar panel continously, and if you touched the metal crocodile clips would you get electrocuted?
    MikeC9
    MikeC9
    This is a peak 4W solar panel, and the raspberry pi generally uses about 1.4W (without any add ons), so it should be possible to run indefinitely with direct sunlight.
    Touching the exposed metal on this is definitely ok: this uses a 12V battery, which is well within the safe limit.
